The Giveaway Thread
have couple of items i'd like to give away to anyone willing to take them:
- hdmi cable (2.0 or 2.1, dont know...nothing etched on the cable). 2~3m in length and well-shielded. never used.
- set of 5~6 CDs of classical music
pickup location thane/mumbai. can also ship these.
May I have the classical music cds, please. The shipping charges will be borne by me.
Thanks and regards
Please book HDMI Cables, I will take it.
I have a request: If anyone has an old Raspberry Pi they no longer need and are willing to give away, it would be greatly appreciated to support a newbie learning project. Please. Thank you in advance!
I might have a pi2. If it's okay, it's yours. To be picked up from Bangalore.
Sony HT s 40R soundbar plus subwoofer+ surrounds. Perfectly working via HDMI arc. Only problem is it's display on subwoofer unit doesn't work. Anyone wants to take please take it from me to repair and use it. Local bangalore pick up only. Area : yeshwantpur
I can pick it if it's still available.
MaSh
MaSh
Thanks a lot for your quick response and the option provided. I would like to try my luck by waiting a day or two to see if there's any possibility of obtaining a 3B+ or higher and reach you with an update. Appreciate your help!
Does anyone have any of these USB IR receivers that came with TV tuner remotes, mediacenter kit, etc. This used to common 20 years back if you were building a HTPC and wanted to control things on the computer.
I need 2 of these for controlling my numerous raspberry PIs. I just need the IR receiver and not the remote. These are no longer available on amazon, flipkart, etc and will be grateful if you have it in your bin and can ship it to me. Of course I will pay for courier charges, etc
Does anyone have this lying with you? I have this and I had put my raspberry pi inside to make this into a streamer, but my VFD Vacuum Fluorescent Display) has conked off. It probably can be repaired and I have to take a look at it. Most probably the power supply that drives the VFD has gone bad. This officially works only with windows, but I made it work with my Linux HTPC and later with a raspberry pi. This is no longer manufactured and hence I can't repair if the part is no longer available. So my heartfelt gratitude to anyone who has this lying around but not using it. Even if it not working, I can replace few parts and make mine work.
I have a Maruti Dezire Zxi head unit(brand new, unused) for give away. When I bought this car last September, I got the originally fitted head unit replaced at the dealer with a higher model one having rear Camera & display also. Hence the original head unit(no speakers) is available with me if anybody is interested.
Could you please post a Picture of the front and the rear connectors?
MaSh
If MaSh doesn't need then could I have it please..
Edit
If any of you great memebers have any inexpensive DAC to giveaway then please let me know..
Thanks again
Pre-USB era hardware, could be anywhere around 30 year old.
will this help? ( PCI TV tuner card too should also be there in some forgotten box )
Thank you for the effort. Unfortunately this is a serial cable. I have the exact same model with me too. But converting that to an USB interface will be difficult for me. I must have got this somewhere in the very late 90s. The remote however can be used with linux LIRC daemon and the above IR diode connected to the PI GPIO pins. If you have a Raspberry PI and keen to have your PI remote controlled, I can help you with the connections. In that case I can pull out mine (I know where my forgotten box is).
Edit
Thanks again
I will try to locate an Fiio dac. If there will gift to you. Also, if anyone has a template or an old (any condition) plinth for Lenco L - 70 ( same as L-75, I believe) please let me know , thanks.
I have a very old potronics portable speaker and a jbl quantum 100 headphone. I have no use for them, they are working but are not in very good shape.
I thought of asking here if anyone needs them for some diy etc., otherwise going to chuck them in e-waste.
If shipping possible I will take the jbl.
Shipping on me.
John
