Super confused in buying a powered subwoofer
I have ordered Polk hts 10. It's in transit but here is a background picture from net
Connect two RCA splitters to both the AUX channels out of your AMP. Connect the existing cable to one of the output of the RCA splitter and connect another pair of RCA cable from the RCA splitter to the subwoofer. I think this is what the guy meant. You can connect either of the below kind of splitter to each channel. You will need two of each
Purchased the subwoofer. What cable do I need for it. I thought RCA to RCA will do but the guy told me to get 2 RCA to 1 RCA if I want to use the low pass filter, and phase correction. Is that correct?
Wholly krapp. I forgot to ask you what amplifier you are using. Sorry.
Use a Standard 2 wire RCA to RCA connector. Take REC/OUT from your Norge and plug it into the back of the sub woofer. You should not use LFE input for Stereo applications unless the amplifier has a low pass filter.
Read the sub woofer manual
"We have to use 2 x 1 RCA cable to use the LPF control of the subwoofer. The subwoofer pre-out of your amp will be connected with the line in of your subwoofer." This is what they are saying. I don't follow what they r saying
Its most likely that they wanna get rid of the cable they have and make a sale. Its a straightforward connection 2 wire rca to rca.
Your amp doesn't have subwoofer pre-out. But it has recording out which also will function like a subwoofer out with full range of audio output. The easiest is what @sandeepmohan has suggested. Just connect a simple left and right RCA cable pair from the recording out of your amp to the line in of your subwoofer.
If your amp didn't have recording out then the only option you would have is to use a one RCA into 2 cable or the MX splitter that I posted.
There is no rocket science involved here
I am confused because I have never connected a sub before and the dealer is saying that if you want to use low pass filter function you will have to do this. if the simple RCA cable would do I would much rather prefer that, as it is easily available online. I Apologise if I am repeating myself but I am being extra careful as the dealer said that I have to make sure that everything is okay on day 1 so I need to get the cable before the sub arrives.
Your amp doesn't have a low pass filter to implement a subwoofer out. Yes. the humble and simple RCA cable will do.
All you need to do is get the cable and connect your rec out of the amp to the subwoofer in. Your subwoofer has a low pass filter which can be controlled by a knob on the subwoofer back plate.
The Dealer thinks you are using an AV Receiver. As is mostly the case. Can you tell them that you're using a Stereo Amplifier!
Like I said earlier, there are clear instructions in the manual. Follow that and signal that to the Dealer as well.
My other advice to you is to never make a rushed purchase. Dealers like these must be avoided as they are giving you wrong advice.
I have a hunch that if the pre outs on your Norge are fixed output, you might find that the sub woofer is playing even at Zero gain. I'm not sure how your Norge works as far the Pre out levels go. I don't think it will be controlled by the amplifiers volume pot. Which means you'll need to control via the sub woofer gain knob.
Had I known ahead that you were purchasing a sub woofer for use with a stereo integrated amplifier, I would have suggested another sub woofer with line level inputs.
You were right you, even though I told him it was a stereo amp and the brand and everything he was still thinking about AVR. he said normal 2*2 RCA would do just fine
The subwoofer just arrived. I have connected them with my amplifier with the RCA cable but they don't seem to be working. In auto mode they are humming/rumbling without any input even if I disconnected with the amplifiers and in DC control mode, they don't same to be working at all. Pls help !
(It happens if I connect the RCA cable to the sub. whether it is connected to amp or not doesn't matter)
Isn't connecting rec out direct to sub, going to prevent the sub volume from changing when the amp. volume is changed? So every-time amp. volume is changed, sub volume has to be changed correspondingly to keep the balance.
Sid
Sid
yes. That would happen whether you use the rec out or the RCA splitter method. Ideally there should have been a output after the volume control as a variable pre-out. But unfortunately his amp doesn't have a variable pre-out and his subwoofer doesn't have speaker level input AFAIK.
Its norView attachment 88645ge concerto gold
I think this amp has a headphone output. If the head phone o/p stays on even when the amp. is powering loudspeakers, then you are in luck. You can use a rca splitter at the headphone output and connect 2 rca cables to you sub. That way, as you very the volume on the amp. the corresponding change will happen in the sub., and all frequencies will be balanced. It is not the ideal method, but it may work.
Sid
Are you saying its humming/rumbling even without any audio cables connected to the sub? If Yes, the sub woofer is faulty. Send it back and ask the dealer to replace the unit. Or ask the Dealer to come and inspect the unit.
To some of the other who posted the question about connection to the sub. That is my bad. I was under the impression that there was a LFE pre amplifier connection available. Hence I recommended the HTS10. Had I know ahead it was a stereo integrated amplifier with no LFE or variable volume for the pre out, I would have recommend a sub woofer with a line level input.
Or his line out has a problem.
Turn on the sub without the RCA cables, gradually turn up the volume and see if it makes a noise. If it does the unit is faulty as Sandeepmohan has suggested, else you have an issue with your line out
Without any cable - no noise. Pin drop silence. Even when I vary the sub volume.
With RCA cable connect to the sub (which is NOT connect to amp) makes humming noise which starts a few seconds after power on and increases lineraly with sub volume
With the RCA cable connected to sub but the other end not connected you will get a hum because your RCA cable is open and hence high impedance. It will catch the 50 Hz mains noise. Have the other end of the RCA cable connected to your source (not the amp REC out). Keep your amp off. If you just get low frequency sounds without any humming, then probably your amp REC out has a noise problem.
Recently I got my power cable replaced on my amp, but as pointed out by @mbhangui I think the local repairman screwed some of the wiring.
If any one has norge concerto gold amp, Could you please share the image of the internal especially where power cable connects and the ceramic capacitors on the red speaker terminals, so I can match and see what wrong.
The photos were not clear and most probably there is no capacitor on the speaker terminal. A better photo can be found here
It is clear from @Shammi Dang photo that your IEC socket doesn't have a fuse. Did the local repair guy replace your IEC socket too?
Since you mentioned that there was lot of sparking happened inside the amp, you better check the connections on the IEC socket. Maybe the repair guy switched the neutral and earth wires. Also the fuse is missing which can save your amp from such miswiring on the socket side. With a multimeter you should check if there is any connection between the phase terminal and earth terminal and also any connection between the neutral terminal and the earth terminal. Show the photo to Laxman from Norge. He should be able to guide to get the amp connection fixed and have a proper IEC socket with fuse fitted there.
He only replace the power cord and did that in front of me. I'll get in touch with Mr Laxman and proceed upon his recommendation to get it rectified with some proficient local electrician or send it to norge. I unfortunately have no skill when it comes to electrical components
