BIC America Subwoofer Pl-300
ARAVIND RAJ
Chennai
Does Bic america subwoofers Need different power cord for 240VAC?
Do u guys use the voltage switch to set volate to 240VAC?
Is it worth buying a BIC america subwoofer in 2025 in India?
Usually, the supplied power cord suffices unless its really of poor quality, My previous BIC subs never had this Voltage switch.
Audition. Check on After Sales Service (Warranty Support) and then compare with other brand of subwoofers in terms of performance, cost and warranty and then take a call.
No one have the Bic for audition here
I didn't like the looks of bic pl300 but the new model looks kinda ok,between bic SWA122 and Elac ps250, the elac sub has an android app and auto eq function.
Bic is okay okay. Avenue sound is also okay with service. When I bought pl-300 it had manufacturing defects. It took almost a year for avenue sounds to replace it. The second one is better. Offlate I noticed it is also rattling at higher volumes.
The performance is nothing to write home about. No punch. I would skip this and go for someother brands. Don’t fall for 15 hz hype. If a cabinet is tuned to low bass, unless you have a huge driver and cabinet, you will sacrifice in midbass. Midbass is where you get the punch. Check out ascendo sv12, whaferdale 15 inch, rel ht series in that price range. I wouldn’t suggest bic pl 300.
