Check this out NTFS.com NTFS vs FAT32 FAT16 FAT.Comparing.Performance.
You may be able to go max upto 32GB.
Gr8 idea, I am trying to open the Philips website but the damn thing refuses to open. I really want to demo the player. Do Philips 5996 have slot load system ?
Shailender,
As far as I know only FAT formatted external hard disks can be used with DVD players. Flash drives of whatever size may be used without any problem. Till date I have only connected flash drives to my DVD player.
I have an 80 GB external USB powered hard drive that I will copy movies and try connecting later this weekend. I will let you know how that goes.
The DVD that I will be trying this on is the 1080 PK from Samsung. But just as a piece of information I have heard that the DVD players at this range may not able to drive 80 GB hard disks. But I will confirm and post in this thread.
thevortex, thanks a lot for the clarification.
Illusion, most of us on this forum would highly appreciate
if you can tell us about the software needed to format the
hdd to play on DVD player.
Thanks once again.
Warm Regds / Shailu
Sure sir,. I will try to post the same by eod today or tomorrow max if possible.
Is shailu your pet name ??
Thanks once again.
Warm Regds / Shailu
Got it . It is "CompuApps SwissKnife V3"
Source: AVS Forums - Phillips 5992 thread (The avsforums link was posted in this thread a few days ago- please go through this thread to locate the same).
Linky (CompuApps SwissKnife v3) :-
CompuApps, Inc. - Download Swissknife
Source : Google
Edit: Forgot to mention that File system Format should be set to FAT32 .
I have not personally used this software so I cannot comment whether the same will work. Use it at your own risk !!
Shailender,
Hi Vortex
Can u shed some light on performance and pricing of samsung 1080pk, it is a USb 2 player, can u cross check wether it is div x or div x ultra certified, as the phillips model is divx ultra certified, also check and let us know how is the play back from external hdd and what all kinds of files it can play of the hDD,
Well Dushie and Shailendar, I tried connecting my USB player. While it got powered on connecting with the DVD, it would not play it. And I figured out why - it was not formatted to FAT. It had a lot of movies on it as well. I will now have to make space for it on my hard disk before copying them on. It will take some time.
In any case I will perform this test and let you know. As far as general USB performance is concerned, there is nothing I would fault the Samsung DVD for. It is quite fine. This is off a flash drive.
I can confirm that the Samsung 1080p is not DivX Ultra certified. It is merely Divx certified. The Philips 5986 is DivX Ultra certified.
I am using LG DV388 since last 40 days... so far I am highly satisfied with its performance.
Its a sleek player with quality picture output.
One of the major reason I went for it was its ability to play movies directly from USB port (using a flash drive - FAT or FAT32 formatted; I havent tried 250GB HD so far since its NTFS formatted and I have a lot of data on it)
I have tried DIvx, Xvid, VOB, MPG formats and all of them played very well on this player (I tried playing with USB as well with DVD) ..manual mentiones abount playin compatibility with 3IVX format as well.
The manual of the player says that the USB is 1.1 and that's where I was wondering if samsung would have been a good buy (1080PK USB is 2.0 compatible - as mentioned in player specifications) but after reading Illusion's reviews of samsung player, I believe my decision to go for LG was not wrong.
My LG player didn't came bundled with HDMI cable. Samsung was providing the same.
Player costs me 3750 INR whereas Samsung 1080PK was available at only one shop at time of purchase and was costing me 4200 INR.
Warranty period for both players is 1 yr and hence I dont think there should be much confusion between samsung or LG brand since both are more or less of same category.
Hi vortex, I am not very sure whether you red my review comparing both LG and Samsung earlier in this thread. To be very frank I was shocked that the Samsung was performing so poorly . Now I am beginning to believe that the cause may be due to some lack in setttings for which the output would have degraded so. This is merely for the fact that I have heard so much about the Samsung DVD players especially the HD860 , that the prima facie difference in quality between two models ( HD 860 and 1080-pk) cannot be this much.
I was thinking of sharing some DivX clips with you and was wondering whether you could play those clips on your 1080-pk and then post some snaps of the same? This would be the best possible way of knowing as to how the 1080-pk will perform under optimal settings . Thanks in advance.
That would be a nice idea to check compatibility. Personally, the only clip that the DVD would not load since I bought it was the Mumm3 divx file I had downloaded from a torrent source. Since the movie was not very special, I did not bother to investigate more.
But certainly it is not a bad DVD player. It is not without its quirks, but it is not bad at all.
I will need to check that, Dushie. I will check and confirm in this thread tomorrow.
I was thinking of creating 3 files:-
One divx ultra sample file which i will be creaing myself
Second would be a high motion clip from the movie Fast and the Furious
Third would be the movie clip of Goal which I had used to demo the 1080-pk and after which I noticed blurring on face closeups!
