Bit-Perfect Sound output from your PC
I havent bought it yet...looking out for options in Borderlinx./Shop yr world/ and 20noth...All r quoting prices above 1200 but the product price is just 6 dollars.
Lets see...If i don get a good deal...will go for DIY method,...
I think you should ask your local computer dealer to source this or a similar connector. A lot of motherboards come with such cables and your dealer should be able to find one that works to give you an RCA output w/o a lot of trouble.
-- no1lives4ever
It is indeed better than foobar2k.Thanks spiro. Where did you discover it?
I didnt understand the settings as i dont understand japanese. But no need to do any settings. The sound is much more life like. I dont care whether it is bit perfect or no. Appearance is also minimalistic. Uses less than 20% of my Atom processor of netbook. Good enough.
This player is purely musical.Yes I cld change sound output setting.You can select 64bit out also(currently not supported by soundcard).
Vocals are better than foobar.Overall analoge like sound.Background details are fuller.
I opened help file,then copied word to word & then paste in online google transfer.
Now I can match the Japanese words with English & read the menu.
I found reading somewhere in website.
Indeed the Vocals are very sweet and life like. In addition I found it to be better for percussion instruments as well. The way you found out setting seems to be bit cumbersome. I think i will leave it with default settings for now. The sound is so pleasing that i dont think i should touch settings.
By the way is it audio player only or video as well.
It played the mp3.
The shows a line 'a!poro ... Sound quality is not skinnable.' What does it mean?
Well it can play flacs,WAV,WMA,MP3 & others.Its audio player & advertised as tube like sound.
"a!poro ... Sound qualiis ty not skinnable"?
something like cant make bad source file sound better perhaps.
