naviworks
I found this: Array R2 Mini ITX NAS Case w/ 300W SFX PSU - Fractal Design
Could not find it in india, ebay or amazon. I have contacted them directly and even a reseller. How ever i think you should go for a generic cabinet. Let me tell you why.
1. Generic cabinet, Low cost, easy availability more slots for adding hard disks at a later time
2. Will work with a standard PSU. The WHS that you have suggested has a power adapter (12 V, could not find current rating). What if it conks off? you will have to find a suitable replacement ( I know you are not buying this but this leads me to my 3rd point)
3. The small factor they achieve is due this power adapter, they need not house the power supply in the cabinet.
4. The cabinet you suggested has hot swap slots. I could not find any cabinet at that size that has hot swap slots. More over Hot swap is the feature of SATA controller of the motherboard. If the motherboard chipset supports AHCI and hot swap, you can open the cabinet, pull out the power of the relevant drive (be very careful not to plug out the wrong one) remove the hard disk. you will have some money going for a generic cabinet, may be you can get an extra hard disk from the money saved.
5. Moving on to WHS 2011, the license will be around 3-5K. why not go for something like freenas so that you save that money? ( if you are going to use the *ahem* version, then i dont mind) FreeNas supports all protocols that WHS supports.
6. 25k is more than enough for the rest of the hardware.
7. Hot swap feature is best left alone.
Let me know what you think
hmm i felt many times why india has limited options in almost everything....ok a generic cabinet and no hot swap feature for me....ya i can accept that but i cannot live without small form factor for a nas (aka home server in my case)
can u give me options for
1) mobo (mini itx, usb 3.0,) what is the max number of harddisk that can be attached internally to a mini itx mobo?
2) processor (a powerful and graphical one not required as it will be used only for storage and streaming but a future proof one is expected)
3) cabinet (a small gud luking, cool and quiet which can accomodate 4 to 6 3.5 drives)
4) psu.
Am willing to pay for the licenced version of WHS 2011 but if the overall budget is out of limit, i ll be forced to use the *ahem* version
some more questions
1) what will be the approximate boot up time for the machine and how drastically will it reduce if i use SSD for the OS?
2) i hope the monitor is not required for the machine
3) will the free nas be user friendly as whs 2011
4) i already have a 250gb and 1 TB drives, the next one i buy will be 2 TB and then may be a 3 or 4 TB (when it comes to the market and depends on how fast i fill it). so i hope this mix n match doesnt affect the performance also since WHS 2011 shows the total capacity as one big single drive, finally if i want to replace the old 250 gb with a higher capacity drive i ll just take out the drive copy the contents and insert the new drive . am i correct or am i missing something?
