spirovious
For mp3,windows media player also sounds better.
For lossless you can try Lilith OR MPCHC.
Have you sorted this problem out,even I am facing the same issue.
Well I am noob in these mattersjust learning the tricks,well I downloaded ASIO4all program and that way was able to use it.Will try wasapi later,by the way which is better.
Update: Opamps changed
For purpose of making the above process easier for noobs, I'll post details of how to change opamps very soon.
Regds,
can anyone tell me the sound quality of Asus Xonar vs Digital players like Popcorn hour ? or Elektron EHP
My plan is to assemble a silent PC with Intel Atom processor and Asus Xonar sound card and retire my existing media player. The thing is that my present Elektron sounds very good to me and i have a DAC to it so it increases the SQ but the firmware issues and other software availability makes this cumbersome. If Asus Xonar can sound as good as a Popcorn hour then combined with the ease of a PC, there is very little that can beat the user friendliness.. What do you say ?
I can't hear mine! Actually ...I can't hear either of mine, and one is exactly one arms length away from my ear.A sound card will make noise.
Hi Cha
--G0bble
