sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,239
- Points
- 113
your internal ip (can find it in xbmc screen as well)
OR START => RUN => Type CMD Enter
Type ipconfig on the DOS screen.....
There are couple of varients of 3D floating around. The original is called the Frame Sequential 3D, that is present on all original 3D BDs. You need a proper BD player that supports 3D BDs or ISOs (frame sequential) to be able to play 3D. (apart from the 3D capable TV ofcourse)
Another common and effective 3D is the SBS (Side-by-Side), that may or may not be derived from original 3D BD, as any movie can be converted to SBS 3D. Most of the 3D movies floating around in mkv are SBS 3D. The advantage is that, you dont need a 3D capable player to play these files, any normal media player/computer can play it, including a normal 2D DB player. (all you need is a 3D TV that can render SBS format (which mostly do, in todays scenario))
How ever 3D ISO and disks are complete frame sequential 3D movies and can only be played on proper 3D capable media/disc players.
For SBS 3D you dont need HDMI 1.4. 1.3 just does fine, however for 3D BDs or ISO (frame sequential) you need HDMI 1.4 capable player.
Few things you need to be clear, for that I will quote my post again that I made in your thread only to make it clear what 3D requirments are AFA PC goes.
Thread of this post ...
http://www.hifivision.com/blu-ray-d...rders/21775-some-queries-blu-ray-players.html
So Fusion will definitely support SBS format as it only needs, HDMI 1.3 ...... Not sure if the the GPU on Fusion platform will have the juice to play full frame sequential 3D ISOs. Even intel's HD3000 graphics are not stable while playing frame sequential ISOs. A dedicated GPU like GT440 which has HDMI 1.4 is recommended for frame sequential ISOs.
You need a SPDIF HeaderOther thing is my motherboard doesn't have an optical out on the rear I/O panel but on closer look at motherboard it seems there's a provision for S/PDIF connector which can be soldered, have you seen something like this and is it possible ?
TIA
I remember the earlier post, however my question was two folds
1. Will the 3D BDs be playable on Fusion all by itself, I am not sure if the HDMI version is 1.4 or 1.3
2. I will provide an example here, if I put GT440 on my fusion board (4x PCIe on a 16x slot) will it be able to pull 3D BDs? Same question for my intel based dual core mobo that I mentioned in my earlier thread which has a 16x pcie slot and if I put GT440 in that will it be able to pull 3D BDs (from BD Rom if attached) or for 3D BDs it is a must have to keep minimum i3 or i5 processor (and supporting mobo) since I read in another post here that GPU power matters more than CPU in graphics rendering in HTPC.
Fusion (E350 as an example) has enough on board GPU power to play all HD content A and V and I am sure 3D SBS as well. However I could not find anywhere which HDMI it supports. So on the safer side yes putting up a GT 440 on the board (but only on x16) should be able to play 3Ds. There is not enough mention on any online forums or reviews that it needs i3 or i5. E350 has a dual core 64bit CPU which should be enough to play 3D, as its more of a GPU task to render then CPU. In worst case the CPU utilization would increase, but I dont think it would simply not play the 3D FS content if a dedicated 440 is supplied.
^^ All the CPU does is decode the H.264/Divx files, apart from ofcourse loading the file on RAM, opening the application etc, the job for rendering the image is on the GPU, so any low end CPU (like yours except, may be celeron dual cores) should be sufficient to play the FS 3D files. You would feel the difference in application taking time to open the 3D files, etc, but once its loaded on to VRAM it should be fine. I would suggest to go for 2GB DDR5 version of 440, just to be on the safer side. (though it might be a bit expensive).
Also hope you have Core2Duo dual core CPU and not Pentium Dual core. Though even Pentium dual core should be sufficient, if its C2D then it completely eradicates the risk.
You mobo is just fine, more then sufficient. Even I have a P5B mobo and it still rocks. Yes CPU I have is C2D (HTPC I am talking about) and not the pentium dual core, which might make a difference in the performance.
^^ Not sure under which criteria did these people laid out the requirements to come up with that list. Anyway As I said your mobo is fine, in the worst case scenario when you test and do face issues, keep the mobo same and try to get hold of a used C2D, any C2D should not be more then 2-2.5K. 2GB ram is ok. For GPU get a 2GB DDR5 one for 3D playback.
Also get Win7 its far better then XP in terms of video playback and gaming as well. XP is outdated now. Get win7, home premium if possible.
Yep, its the same again GT 430/440/450 .... Pick any. My GT440 1GB DDR5 does the job perfectly. Full HD with full 7.1 HD Audio bit streaming.![]()
For game playback its advisable to have faster memory, logically same can be said for HD Videos. I would say go for 1GB DDR5. Even I have the same for my HTPC.![]()
But sam the specs on the website says that DDR5 is only available in 512MB configureation and the 1GB is DDR3 only.
@ all,
after a few days of research this is what i've selected as an upgrade for my htpc - dual display and s/pdif out are a must.
I have - proc - e5300 dual core 2.60 ghz + cabinet + dvd writer + logitech wireless keyboard/mouse + cheapo ram - dynet 400 mhz (shall i buy new one ?
Can you please share your views !
zotac geforce - gt440 gddr5 [ 1 gb ]
ga-g31m-es2l
psu option 01 or psu option 02
asus xonar dg
if required -
g.skill ddr2 -2gb
tia
