sam9s HTPC Project! powered by XBMC!!
^^ Use Smart Playlist option ..... I have explained that I think at post 257 ..... you can then disable the category "Video" from settings.
Thanks for the pointer on XBMC, I'm loving it. Installed XBMC on my home PC and connected the PC to my AVR via HDMI. Now playing songs or watching movies from my PC to AVR/TV is so easy. Wish Xtreamer also had the same interface.
Has anyone configured weather updates recently in XBMC ? I just cant seem to make it work :mad:. Here's what I've been doing :
(skin-transparency,if that matters)
Settings --> appearance --> International (Region - India 12h/24h)
Weather --> change area code 1 --> New Delhi
Weather --> get more --> Weather plus
Settings --> provider (accuweather/english) --> run location selector (New Delhi) --> XBMC search 50% - error script failed !!!
Someone please help with setting up weather updates in XBMC.
TIA
Bought Zotac zbox Nano AD10 yesterday for my HTPC. Total cost about 21K which includes 1.3 K for 4 GB RAM ( G.Skill) and 4k for 500GB (2.5" HDD from Hitachi).
I will install OS and XMBC for HTPC. Which version of windows 7 works best with XBMC?
I will post the pics after I reach home and also its feed back. Presently I'm in Kolkata for some official work.
@Sam9s and Baiju...please let me know how to complete the process, what is it I am doing wrong ???
(skin-transparency,if that matters - net connected at all times)
TIA
seems you r doing it right .... I have to recreate the scenario to see what could be wrong as I configured my weather settings the very first day I installed XBMC on my HTPC and since then havent touched those settings, so cant remember if I followed exactly the way you are doing here ...... let me get back to you ....
Hey Sammy,
I've added my movies to library,changed skins, make it boot directly in XBMC - all with the steps provided by you...but this @#$% weather just wont work.
Also, on startup I get Intel BIOS screen then win 7 welcome screen and then it loads XBMC.
Though bios and win 7 welcome screen appear for a short time - is there a way to bypass any of these or else have custom picture etc instead ?
TIA
Weather plus and other weather plugins are not working for me also. Weather Plus worked for me only once when I tried a few days back. I added Cochin as the location. Now XBMC shows a 'Internet connection required' message. Probably that plugin has some bugs.
You can change the windows animation and startup screen, I have discussed it in my HTPC thread.
Hey Sammy,
mmm let me check....
TIA
I was hoping to add these steps, but since baijuxavior have added nicely I will point you in that direction. How ever the tools I used differe a bit.
1. I dont use Event ghost at all. I use windows 7 MMC console to boot directly in to XBMC.
2. I apart from Win7LogonBackgroundChanger and windows 7 boot updater, I also used Logon screen tweaker to get the desired result.
You just install, Win7LogonBackgroundChanger and windows 7 boot updater and you should be able to get rid of windows logon screen. Steps are easy and self explanatory .....
About getting rid of the BIOS logo screen, thats a bit complicated and would depend on your BIOS itself. Let me prepare a details explanation to achieve this ...
check this link for weather
I'll try it once I get home..thanks !
2BackgroundChanger and windows 7 boot updater[/B] and you should be able to get rid of windows logon screen. Steps are easy and self explanatory .....
Are you still getting weather updates ? because this is what I found on XBMC Weather
I too have used the steps provided by you and load XBMC directly as a shell via windows 7 MMC console...really easy and very neat...BIG THANKS mate :)
Can you please provide the steps to do so...I'll try and experiment with both options (yours and Baiju's) and see which works best for me !
Are you talking about booting into xbmc or changing the boot screen appearance? You don't need eventghost to change the boot screen. Just follow the steps I posted.
I forgot to add. Weather worked for me with the Pre-Eden version which I am using on my HTPC. For the Dharma version on my laptop, it shows a script error message or Internet connection required message.
I've managed to boot in XBMC directly using MMC / custom user interface...thanks
I now need to change the boot screen...will try it once I get home...If I get stuck I know where to find you :D, hope its alright !
I For the Dharma version on my laptop, it shows a script error message or Internet connection required message.
I clearly remember seeing dharma version while fiddling with weather settings and bingo I too get that script error message at the very end of the process just after where it shows XBMC 50%...does that mean I have downloaded and installed the Eden version in my system ?
