Has anyone configured weather updates recently in XBMC ? I just cant seem to make it work. Here's what I've been doing :
(skin-transparency,if that matters - net connected at all times)
Settings --> appearance --> International (Region - India 12h/24h)
Weather --> change area code 1 --> New Delhi
Weather --> get more --> Weather plus
Settings --> provider (accuweather/english) --> run location selector (New Delhi) --> XBMC search 50% - error script failed !!!
Someone please help with setting up weather updates in XBMC.
TIA
I will install OS and XMBC for HTPC. Which version of windows 7 works best with XBMC? .
seems you r doing it right .... I have to recreate the scenario to see what could be wrong as I configured my weather settings the very first day I installed XBMC on my HTPC and since then havent touched those settings, so cant remember if I followed exactly the way you are doing here ...... let me get back to you ....
@Sam9s and Baiju...please let me know how to complete the process, what is it I am doing wrong ???
Also, on startup I get Intel BIOS screen then win 7 welcome screen and then it loads XBMC.
Though bios and win 7 welcome screen appear for a short time - is there a way to bypass any of these or else have custom picture etc instead ?
Hey Sammy,
I've added my movies to library,changed skins, make it boot directly in XBMC - all with the steps provided by you...but this @#$% weather just wont work.
TIA
Weather plus and other weather plugins are not working for me also. Weather Plus worked for me only once when I tried a few days back. I added Cochin as the location. Now XBMC shows a 'Internet connection required' message. Probably that plugin has some bugs.
You can change the windows animation and startup screen, I have discussed it in my HTPC thread.
mmm let me check....
I was hoping to add these steps, but since baijuxavior have added nicely I will point you in that direction. How ever the tools I used differe a bit.
1. I dont use Event ghost at all. I use windows 7 MMC console to boot directly in to XBMC.
2BackgroundChanger and windows 7 boot updater[/B] and you should be able to get rid of windows logon screen. Steps are easy and self explanatory .....
Can you please provide the steps to do so...I'll try and experiment with both options (yours and Baiju's) and see which works best for me !
Are you talking about booting into xbmc or changing the boot screen appearance? You don't need eventghost to change the boot screen. Just follow the steps I posted.
I For the Dharma version on my laptop, it shows a script error message or Internet connection required message.
