sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,239
- Points
- 113
OK I think now you are directly logging in to XBMC skipping windows right....?. To get the ip follow the below steps.
1. Log in to XBMC as you normally do.
2. Once you are in to xbmc, press ctrl+alt+del from key board and click on start task maneger.
3. Once the task manager is opened. Click on ALT and then press enter and then again enter.
4. This would open create new task window.
5. Type in cmd and then press enter.
6. Now you are in command prompt.
11. Just type ipconfig and note down the ipv4 address.
12. That is your internal IP. It should be something like 192.168.x.y
13. type exit and now open XBMC remote and configure it accordingly.
some screens to keep you familier.
