Added a new "member" a London decca Mk V EE cart whch i picked up on ebay Japan and just set it up
it is like a Diva.. plays the most beautiful sound on clean , well recorded LPs...mesmerizing
But put a dirty LP and it spits and snarls :sad: ..not sure how to manage this temperamental star
cant have 2 tonearms.
Whatever it is..definitely a Keeper.
some history
Now to go for a PTP5
some history
It should be observed that these version of the London carts have been hyped up much in the last few years and they do indeed have redeeming qualities, but you should be aware of a few facts before parting out with your hard earned cash, firstly the pole pieces contain iron, these are after all Moving Iron and not MC designs, so they rust and break off so the lifetime of those carts is not all that great this is in paticular a problem with early variants, secondly the cantilever less design of the carts mean that they collect an unusually high amount of dirt inside and need to be cleaned frequently, however the top of the cart can be slid off for adjustment of the channel separation (all the way to mono BTW) and can help in cleaning the cart incidentally, thirdly they are sensitive to grounding, much more so than most carts and finally these MkI to MkIV version while similar in design to the current versions they are much bigger and heavier and can be a pig to set up and will only mate rally well with a heavy or damped arms. The MkV was released in the mid/late 70's and is the basis for the cartridges that are being made today, while it retains the peculiarities of earlier designs such as the wildly differing vertical and horizontal modulations the new design was much lighter and smaller than earlier models and thus it was easier to match them to modern arms.
