Mordaunt Short Mezzo 6 or Aviano 8
R Narayanan
New Delhi
Hi Guys
Have any one of you demoed Mordaunt Short's Mezzo 6 and Aviano 8 at the same time? The Mezzo 6 is probably 20 K or more expensive of the two. The question is should the budget be stretched by that much? And are the returns worth it especially to listen to lounge music?
I know the Audiophile response but I hope you guys will also think thru your pockets.
I will wait to read your response. Many thanks.:)
Buying Aviano 8 will require more powerful amp which might end up costlier than the 20K. Not sure how big is the area you want to cover but for a medium hall Mezzo 6 would be better definitely.
Thanks for your response. But what kind of a wattage do you think would be sufficient to drive the aviano 8 and get the best out of it?
I fail to see why is that so.
Both the speakers have almost the same sensitivity and impedance.
Because of more drivers?
But that is no reason to ask for higher wattage amp.
Are you getting Avianos in Delhi ?
Here is Mumbai most dealers are out of Avianos and they say they have been out for months. They only have the Mezzos on offer now.
I heard the Mezzo 6 last weekend and it was very nice speaker. Though for about 10k less, the Paradigm Monitor 7 was almost equally good. Infact I preferred the Monitor 7 sound to the Mezzo 6
Hi Alpha, If you look at the specs Aviano 8 is rated for more continuos power than Mezzo 6 and also the fact that Messo 6 has more sensitivity that Aviano 8. So set aside loudness I believe to explore the full potential of a speaker with higher RMS ratings and lower sensitivity you will eventually end up for a more capable Amp to drive, probably a costly stereo amp or an even costlier AVR to say the least.
The sensitivity lower by only 1 db where as the max power is higher by 50 w for aviano 8
The aviano 8 are costlier by 50 ponds compared to mezzo 6 on richer sound web site??
