Shivam
the Zephyr is an aluminium casing ?
i was proposing to have that in my build too
but another client and dealer adviced we used pine
My distribution Box
should have the following specs - it is basically a passive device
Lapp cable point to point wiring 3mm sqaure
20A surge protection unit
EMI RFI filter
pure copper lugs from Mennekans
6 Sockets from Schneider ( germany) - Copper based 16Amp rated
Custom wood casing with damping
size is not small
a 6 pc box will measure about 6 inches by 14inches
the components weigh
1.4 kgs
dunno how much the box will end up weighing though
probably rikhav is correct in his estimation
This should be a good option. Zephyr is bigger than my bookshelves.
