spirovious
Hi friends,
I know that this topic is very old,still I saw that many of our new members find it difficult to Bitstream HD audio from PC/Laptop.
So I thought of writing about some Video players which does this job well and you get those Free.
First you have to check if your Hardware supports HD audio over HDMI.ATI HD series(5***)and above.Nvidia GT 4** and above does support it.
popular Video players are Media Player Classic for Home Cinema(MPCHC), Pot Player,XMBC.I will write about first two as XMBC details you can find in forum elsewhere.
Also you have to change few settings in Windows.
Right click on volume symbol(Right side bottom)and select "Play back device"-
Then on top of window,click Configure Speaker.You get this-
Here you can set to "5.1 or 7.1" according to your speaker setup.
Also select"Set as Default Device"as "AMD HDMI out"
using Media player Classic -
Download MPCHC from here-
Downloads – MPC-HC
You need some filters like LAV filters or FFD show-
LAV Filters 0.60.1 - VideoHelp.com Downloads
Free Download LAV Filters 0.60.1 : LAV Filters are a set of DirectShow filters
ffdshow 1.3.4530 - VideoHelp.com Downloads
You need to install either of it.
Also get Haali media splitter-
Haali Media Splitter 23/06/2013 - VideoHelp.com Downloads
Lets start step by step.
Star MPCHC and go to options (View> Optios)
Then Playback> Output. Here select the correct "Audio Renderer" option.In my case its HD5570,so "Direct sound AMD HDMI Output" selected.
If it doesnt works,set it as "system default".
Then go to Internal filters setting and untick DTS,DD,FLAC,MPEG options and select same in Transform Filters.See the image below how it looks.
Now go to External Filters.Here you need to select Haali Media Splitter,LAV Video decoder and Lav audio decoder by clicking "Add Filter".
Double click Lav audio decoder and select Bitstream option in Lav audio decoder setting like below.
Then LAV video decoder and select correct Hardware acceleration.I have selected "DXVA2(copy back)"due to ATI card.You can select "Nvidia CUVID" if you have nvidia card.
Also tick "Codecs for HW decoding"and select "H.264,VC1,MPEG2" MPEG4 if your card supports.
Also make sure that you select "prefer" option before each filter like below-
Haali splitter is used for MKV files and also help to select different audio streams from source video file.
Thats it.Your MPCHC is ready to Bitstream perfectly.
Potplayer is just similar to set with some tweaks.
http://www.videohelp.com/tools/PotPlayer
Potplayer has edge as it can play 3D perfectly.Also Bluray discs easily.Please follow the images below.
First you have to disable internal processing.
Go to Preferences (F5)> Filter Control and you can see like image below.
Here in Condition,select "Disable with following Conditions"And just below that "MPG1 MPG2 WMV2 WMV3 H264 AVC1 WVC1"in Fourcc.
Also untick use "audio processing Filters"at bottom.Else Potplayer will downmix audio.
Then select filters like MPCHC.Click "Filter Management"at bottom and you can see the window like this-
Click "Add registered Filters" there to select from the list.
Then click "Built-in codecs/DXVA setting" and select necessary options like in image-
Video setting
Like you go to Audio Filter option and again Click
"Built-in codecs(S/PDIF,HDMI)setting".Where you can see audio options.Select like I did-
Also check that main window of each Filter should look like below-
Make sure you select Lav filters in audio video settings here.
Also Audio output option like below-
It should work perfectly now.
Finally few setting regarding VLC media player which can send Dolby digital and Dts sound as "Raw" to AVR.
http://www.videolan.org/vlc/index.html
Once you did setting in windows like MPCHC, some more tweaks you need.
Go to tools> preference and select "Audio".Here select "Output module"as "DirectX audio output"
Also tick option "S/PDIF when available".Device option can be "Primary or AMD-HDMI out "
Also got to advance setting by clicking show setting to ALL at left side bottom.Make sure you select "5.1"option in Speaker Configration (DirectX option)as below.
Common Video setting can be like below-
Same in advance settings, select Video output modules options as "DirectX(Direct Draw) video output"-
Now Vlc is ready to stream audio correctly.
If you noticed,we have also learnt to set Video Hardware acceleration.So CPU load should be less now.
Hope this helps you in simple way.Thanks for reading such a long post.Also if I have missed some more settings,please do post in this thread.
Cheers.
Downloads – MPC-HC
Video setting
Cheers.
