Acer H5380BD Thread
Hi, Thanks for your reply, what is the weight of 6:9 HD Foldable Electric Motorized Projector Screen + Remote
Actually i am travelling from Peru to Washington D.C and my main baggage limit is 23kg
The dimensions may be problem to your baggage.
can i buy the below for the screen:
Amazon.com: 120-Inch Spandex Projector Screen. 5'x9', 16:9, 3D DLP Ready, Portable, Lightweight, Wrinkle Free with both Front & Rear/Backlit Projection (Compare to: Favi, Epson, Da-Lite, Goo Systems, Elite Screens, Camp Chef, Mustang, Black O
I have no experience with it.But concept looks great.
(OR)
Amazon.com: Carl's Blackout Cloth, DIY Projector Screen, Raw Material/Fabric, 66x110-inch, Matte White, 16:9/1.0: Electronics
It will be less than 1.5 kgs. Some FMs are using Carl. You can make a frame and fix it.
Please advise.
Thanks and Regards,
Kumar
Better will be, buy projector from there ( also cloth) and screen from here.
Hope you know that there wont be warranty if you brought from abroad.
I agree. Before you leave contact the airlines and see if you can bring the PJ screen(get the measurements from the buyer). If they charge you at the airline It might be cheaper for you to bring it with you. I still say get the ebay Electric Screen it works very well for the price. You can order them before you go to Washington and have it waiting for you at the House/Apt/hotel, so you will have time to test them out.
Sorry for the general question, is it good to use Power Converter Voltage 220V to 110V in india ?,
Kumar
Did anyone take advantage of this great deal? This was like half price on a brand new unit. I got mine from this seller and I've been happy for 6 months now.:yahoo::ohyeah:
Please note,its "Manufacturer refurbished".
Kumar
If the equipment is 110-230v compatible, then there is no problem in directly plug it to electric socket.
If it is 110v, then using a good step down transformer (converter) is a must. Hope it clarifies.
What did you decide?
Hola Kumar! You can check all those gcr mentioned. I got lucky I got mine on ebay Acer Refurb and it looked new with zero hours of use.
I got my Motorized screen on ebay as well. I would not spend more than $80 US on a screen unless you got lots of monies :)(I bid on mine and got it for a little less than $70): New 100" 16 9 HD Foldable Electric Motorized Projector Screen Remote | eBay
Good luck and don't hesitate to ask more questions.
Can you post pictures of your screen ( without projecting).
Can it be connected to our projector so that when switching on the projector , the screen automatically pulls down and goes up on switching off ?
regards
girish:)
regards
girish:)
Yes gcr I can can take pics this weekend. No the screen does not come down when I put on my PJ. I use the remote. I may get a fixed frame later on, but for now I'm happy with it.:yahoo::clapping:
i have decided to buy the below thru Amazon.com:
1. Acer H5380BD
2. ONKYO HT-3500 or HT-3700 ----> 110V
3. the below transformer
http://www.amazon.com/Portable-Univ...to+220v+converter&refinements=p_72:1248879011
Great choice. Keep looking at the prices as it fluctuates.
Do check whether sales tax is applicable or not at your place.
The converter is a travel adapter which will not be sufficient for onkyo.
Its already mentioned in the usage advise of the above adapter. You can buy good converters from here itself so that you can avoid the baggage weight. Look for reputed brands like maxine... .
Yep spirovious but it's like brand new with no hours on the actual bulb. I contacted the seller and he promptly answered all my questions. If I can help someone save money it's worth it. :cool:
Does "manufacturer refurbished" item implies that it had a production defect or might be a demo unit rather than a open box item or minor scratch or dent during shipping which i presume might be the case with retailers. How much big of a gamble it can be for a customer while buying a refurbished item from a Manufacturer or from a retailer?
I was making up my mind to get it delivered at my friends place in US and have it tested for for a month or two before he leaves for India in Aug. Do they increase the warranty period of 90 days at additional cost?
Normally a manufactured refurbished means that the item was repaired/serviced by the manufacturer for any minor flaws and should mostly carry the full warranty as applicable to a new item. I have brought many different kinds of items from US in manufactured refurbished and so far I didn't find any issue with them. So its better that your friend uses it in US and can return back if found some issue rather than finding the issues in India as the return shipping is hassle and best avoided.
Hi elan,
manniraj is correct + it's basically from Acer. You can message the seller. He was very good with a fast response to any questions. That's why I told Kumar and members here about it. You could play with it in the US and if there are problems they could always return and highly doubt you will.
I bought this ( similar to first link, second is not opening). 2 Feet Stellar Universal Projector Ceiling Mount KIT With Screw | eBay white one. Finishing is not that good. It was a ceiling mount. put extra holes to make it wall mount.
Hope your requirement is ceiling mount, so no modifications is required.
