My First DIY Amplifier (JLH 1969)
From where you are going to get the kit/parts, let me know as me too require the psu for the amp
You require a really big heat sinks to handle the heat
I am planning to order the pcb+kit from eBay. For the psu, I think I'll build a CRC psu with a bridge rectifier on a veroboard like this. I am planning to use 30000uf per rail.
I'll be getting two 195mm X 100mm X 32mm heatsinks. The TO-3 transistors will be mounted on a 3mm aluminium L shaped mounting plate.
I'm also planning to use a 18-0-18v toroidal transformer for this project.
Sent from my Nexus 5 using Tapatalk
