Bug Head Player
I'm running WINDOWS 10 64bit with 8gb RAM. I have downloaded and installed this software but its not running. Can someone help me in solving the problem?
Guys nothing is happening when i'm running the exe file after the installation. Nothing shows up. I hope its compatible with windows 10.
The current version is designed specifically for Windows 10 x64.
How do you run it? Did you install the install file, or are you running the executable zip file that needs no installation? And if running the zip executable, which exe - Bughead or Infinity Blade?
If you have older version of Bughead like 6.XX, then try to install this and try to run. If successful then copy all the content of new version and paste into bughead folder in program files of C drive.
What is your processor?? New version supports only AVX 2 compatible processor ( post ivy bridge generation)
Can someone share 7.27 version??
