Garrard RC 210 Tone Arm Rewiring
The Garrard RC210 tonearm is wired for stereo, the mono cart if used, was wired accordingly in the headshell itself. I have a specimen lying here for restoration. Let me take a look and will post the details.
Managed to take some pics. The wiring coming from the headshell jack (the Garrard RC210 uses a 4-pin Garrard headshell) to the junction point below the tonearm is for stereo. One can notice the 2 separate shielded wires reaching the tag board. This one was taken from a mono stand alone record changer (not the radio gram variety) and hence you can also notice how the shielded cable which is intended to go out to the amplifier input, is wired. IMG_20180827_095121.jpgIMG_20180827_095203.jpgIMG_20180827_095121.jpg
Thanks Reuben for the explanation photographs. Attached is my understanding of the wiring. Please advise if this is in order.
I have wired the Changer as per the suggestions of Reuben and it is working fine. However, some hum is there. Suggestions required to reduce the same.
Grounding is very important. The older turntables, especially the Garrards did not have a grounding wire. The outer shield of the cabling to the amplifier doubled as the ground wiring. This is not a very efficient way of grounding. Ensure that the grounded tag of the tag board (below the tonearm is grounded with the cartridge wiring coming to the tag board and also wire this separately to the ground of the amplifier. It is very important to have a dedicated ground wire, or you may be encouraging forms of grounding loops :)
For mono, just wire one channel, using one of the pairs of the tonearm wiring. From the headshell perspective, the RC210 uses a 4-pin headshell, hence you'd need to use just one relevant pair for mono.
