paimpozhil
HI All,
Thank you for the support in advance, I have many questions
I bought a new Denon 6400 Receiver,
I have a dedicated home theater room which is 21' w x 17' l
Since it is a wide room and my seating is nearly close to the wall i.e 2 feet away, should I go with 7.2.4 ? or should I be happy with 5.2.4 or is there any other configuration that will be better suited ?
I used to have 5.1.2 and it was good enough but decided to scrap it as it was a combination of different models of speakers so they didnt go very well together.
Regards to A7 vs A9 :
I auditioned Polk in Pro fx Chennai , I liked it, initially wanted to go with RTI a7 , cs6 , 4x A3 ( real/surround pair) and 4x rc80I atmos ceiling
however now I am inclined more towards RTI A9, would Denon have enough power to do all these?or should i get an xls 2002 amp and use that for the towers if i go with A9?
Regards to Sub:
I already own a Bic America PL 200 subwoofer, I will keep this with the polk new setup but wanted to go with dual, so any suggestions here within 50k budgets?
Regards to Sub:
