Power calculation for home theatre
wrongElk
India
Hi Guys,
After a long 5 year stint in US, I am finally back in India. I shipped my home theater to India & yesterday received everything safe & sound. As the title indicates, I now need some expert advise in finding an appropriate voltage converter (220v to 110v) for my setup. Appreciate any help.
Following are the components in my system.
A/V Receiver: Onkyo TX-NR646
From the spec sheet, I got following info for the receiver.
Power Consumption
6.4 A (North American and Taiwanese)
630 W (Others)
So I believe a 800watts (6.4A x 120V = 768W) voltage converter should be sufficient for driving my receiver.
Sub-woofer: Dayton Audio SUB-1200 12" 120 Watt
I couldn't find any details regarding the power consumption of this unit. Much appreciate any help in calculating the power consumption of this subwoofer.
Speakers: Pioneer
I have a full set of Pioneer speakers (Andrew Jones) which includes a pair of FS52, BS22, C22, T22A. Not sure whether the speakers will come in to power calculation as they are not active speakers.
Depending on your response, I need to buy a good quality voltage converter. Also it would be really helpful if you can point me to some good quality voltage converters. Currently I have my eyes on Maxine 1500Watts Voltage Converter but not sure whether this is an overkill for my system.
Speakers: Pioneer
This should not require any voltage converter as it is been powered through your AVR
