superczar
- Joined
- Feb 5, 2008
- Messages
- 836
- Points
- 93
Whoa!Thanks for that supeczar
Please bear with my rumblings on the chrome cast audio
The problem with source components as compared to high capacity amps, is that their power supplies are meagre. And really don't have room to filter the incoming power. So I have eliminated that problem by running my Chromecast audio from a PS1200 power regenerator proving pure AC power and again filtered by a isotek evo3 Polaris power filter. I also have my chrome cast hard wired with a lan cable to avoid wireless gremlins. On top of all this , I run it off a 5V LPSU. And I can vouch the results are stellar. And very comparable to my almost 30 x digital streamer cum roon end point. One would be hard pressed to notice the differences between the two. And why all this effort to get CCA working well in the first place. Because it is the only way to stream local desi sites like gaana or saavn on good 256kbps quality.
Tell you what, I will go all out and use a regulated pure DC 5V/3A power supply from my test bench to run the test
I will leave the Airplay setup as is given that the DAC for Airplay the primary rig is in the Marantz AVR 6010 which I presume would have decent isolation circuitry for power...
Word of caution though, I hear absolutely fine imaging even on a class D amp hooked to an analog out on a Macbook (as long as the speakers are good)
The wires I use across all setups are all Amazonbasics 14AWG and my RCA interconnects are again amazonbasics
Guess what I am saying is I am probably not the best testing expert
