superczar
- Joined
- Feb 5, 2008
- Messages
- 836
- Points
- 93
First a small anecdote
Some months ago, I decided to wire up a unused amplifier to my AVR to drive the front L/R speakers to offset some of the power delivery when I added ATMOS to my setup. While I do believe that offloading the two primaries to a dedicated amp would open up headroom for the overused multi channel amps on the AVR, the end result got me thinking along a different line.
After I had added the stereo amp to the setup , I ran Audyssey (multeq XT32) on the AVR and was a bit surprised when I noticed that Audyssey boosted the gain on the FL/FR channels by 4db
I was under the assumption that gain settings on all amps (at least mid to high grade) would be set to a reference level so the result took me by a bit of surprise.
Now it’s probably well know that psychoacoustically, a few dB extra loudness makes us perceive the sound as fuller/richer - so It got me wondering if the so called amp sonic differences stem on account of the default gain variance.
Thus I carried out a small experiment on my own.
Common thread - All sessions were set to output a 78db loudness level on a pink noise file by using a calibrated microphone wired to a macbook to set the gain on all tested amps so that they output the same amplitude
Amplifiers tested -
1) Marantz PM17 SA integrated amp
2) Marantz SR6010 AVR in direct mode
3) SMSL SA-160 class D amp
4) Harman Kardon AVR 5000 in direct mode
5) Paradigm PW Amp in direct mode (I.e. Anthem room correction disabled)
6) Sure Electronics TAS5630 class D amp board
7) ultra cheap TPA3116D2 board
I am not sure if its my ears or if it’s something else but honest to goodness, other than (7) above, subtle differences aside, I would be hard pressed to select one over the other
Even (7) wasn’t bad at all but seemed to be running out of steam at what is a fairly high dB level.. I guess it would end up being at par (at least for me ) at more normal listening levels
Source for all the tests was a M-audio DAC hooked to a MacBook Pro playing a 24/192 version of The National’s About Today
Hypothesis : Is it possible that a lot of (not all) perceived differences in subjective assessments of Amps are on account of a gain difference rather than a true sonic difference?
PS: (1) and (2) are the AVR and amp referred in the back-story
PS2: Two sets of speakers were used for the tests , KEF Q300 and Phase Tech Velocity V12 - Arguably neither is a top of the line set but both are critically acclaimed mid-end speakers
Amplifiers tested -
