D
Deleted member 15865
Guest
Further in the subject of Apple Music not able to transfer lossless via AirPlay - it’s so ironic.
I say that because I can easily use AirPlay to transfer Primephonic files from the phone to the streamer and it transfer them in ALAC (lossless) format. Here’s the proof:
So, it’s not really an AirPlay limitation! AirPlay is quite capable of transferring ALAC.
We also saw that when you select AirPlay from the menu bar (and not the Music app) in MacBook, it transfers in ALAC format.
So, clearly there’s no problem with the files streamed from the server which are lossless (or hi-Res). There’s also a capable transfer technology (AirPlay) which other apps (like Primephonic, Tidal etc) use to transfer lossless (not hi-Res though) from iOS devices to the streamer.
So, the problem is just with the way the Apple Music app chooses to use AirPlay. It somehow forces it to transfer AAC instead of ALAC. Now that could just be a result of the legacy design of the app. And if that’s so, all that Apple needs to do is to make the necessary changes to the Apple Music app to make it transfer the files in ALAC format over AirPlay to streamers and receivers. One hopes Apple is reading the flurry of discussions on various audiophile forums including this one on this matter and would soon work on this tweak.
