soundsgreat
Dinyaar you ! Sure checkout Am confident that you should be able to get one easily !!
NandaKumar ,See thats for sure !! but then again why are you soo bent on Krell any particular reason ??
Otherwise the only option is to check for all the stuff posted here and confirm 100% then buy !!
But I'd still recommend you to check the Odyssey !!
Regards.
Regards.
