A sight to BeholdFinally the Speakers are singing.
good job @sadik
Thankyou
Thankyou @anilvaAwesome. Your approach and build are so impressive. Very very professional. I am very envious of your workshop!
Yes you are Right, They were monstrous Enclosures, Now this Enclosures are with better drivers and far more superior then them.Awesome! You made a single enclosure beasts for the same client AFAIR!
Yes they will be difficult to make unless one is using a CNC router. Plus we must have a proper dimensional drawing otherwise the new grill will not fit. And yes it will be expensive, once it comes to CNC it gets expensive. Plus packing charges will also be on higher side as the grill itself will be very weak and it will need a heavy packing to prevent damage in transist.@sadik would making speaker grills like the arphi aquarious be very difficult and expensive?View attachment 63188
Thankyou..see post #12These look dope, and the white just brings out the elegance in them.
What gear is powering them? might need loads of power.
Can you share a youtube video of them singing?
Which is the Amp? Black on left...Finally the Speakers are singing.
Super bhaiFinally the Speakers are singing.
Its a DIY amp, designed by FM @AniketWhich is the Amp? Black on left...
Yes, you are absolute right, even I have heard that klipsch use B&C pro drivers for their woofer systems.Thank you, Actually designing and making enclosures is just my hobby, its not my Bread and Butter, I have a manufacturing unit (Gear Pumps) which is my Primary source of income. I take the Orders only if the customer is ready to wait for atleast 2 Months to get the delivery. Amp is not done by me, however in this case the Enclosure of amp, may be I will built, right now its not sure. The MID is 8MC300Nd & Woofer is 18LEX1000Nd both are from Beyma. Belive me there are few PA drivers, if designed and used properly will give a tough competition to the HiFi drivers. Among the few these models,from Beyma, one can use for home audio.
I don't know weather they will be covered or not, its the user who has to take care of it.
Class ApartFinally the Speakers are singing.
