48" display for our Unreal Gaming Engine presentation
joyceanblue
new delhi
Hi friends, I mostly work in Unreal Gaming Engine to present my Architecture Viz work, right now I need a 48" display to present my work (i have arranged someone to put a touch overlay on it). But the panels I tried running my presentation on look significantly different than my pc monitor. I assume the big panels are optimized to run cable/dvd movies. So are there are any big panels which can reproduce the colors the same way a pc monitor does? My budget is around 50 to 60k.
Thanks and regards.
What monitor are you using at the moment?
Sent from my SM-A910F using Tapatalk
I tested those panels in the touchscreen providers workshop, we too reached the conclusion that they need good calibration to match the color profile of our pc monitor.
Ya what I would do is get a cheap data colour display calibrator and calibrate both the monitor and the TV only then can you expect a colour match.
