Hisense U7K user review thread
I've counted 36 horizontal and 36 vertical dimming zones, giving a total of 1296 zone
Did you use AVS zone counter? Should be diagonall count be the same? My buddy counted zones and he got 36x36 too. But number in diagonal row is less
How good is black level on this set? For dark room watching?
Especially considering wide screen where black bars are main distracting factor with local dimming being not perfect. It is very annoying for me :)
What about 85U7K?
Black bars are close to black but not exactly black. Let’s say if OLED is zero brightness on black bars, IPS panel is 100 brightness, VA panel is 20-25 then U7K is around 1-2.
It’s more about how the local dimming works. Hisense has chosen for smoother dimming across a few zones to completely eliminate blooming but it means that you don’t get pure blacks unless you go 2-3 zones away.
If you have a pure black room, then go with an OLED. If you look for it the U7K black bars will bother you a bit. But even if the room has a little bit of bias light or isn’t pure dark you won’t be able to distinguish between this and OLED
Any info on this??
What info you want on this. 50+ people on the telegram bought this tv.
Apart from the units which arrived defective and were exchanged, haven’t heard a single unit go bad. Mine is working fine too.
You need to have a 1000+ sample across years to make a good decision though. So I can’t help you.
1-2% is very good result on 100% scale actually :) . It turns out to be very close to OLED blacks. I had TCL 65C755 recently and i would give it 8-10%. I guess i will be totally satisfied with such black level as 1-2 from 100 😁
It is not clear till the end how much dimming zones it has. RTings say about 684. You say about 1290. Big difference. Are you shure number of zones was counted correctly? Did you use AVS zone counter?
It’s not a scale. I’m talking about black levels. I’d say the 65C755 would also be at most a 3-4. No way it only has 3x the contrast of a VA panel.
The overall dimming performance of the U7K is impressive but the black bars are a software tuning issue and the weakest part about this tv.
The Indian variant of 85U7K isn’t the same as the US variant.
The Indian 85” U7K uses the same panel as the Chinese variant (called U7K pro I believe) which is similar to the US U8K.
Yes, I counted the zones correctly. It’s a 32x32 grid. I used the YouTube video with tiny dot running around display.
Easily in some situations. 1-2 only in most simple scenarios where most part of the screen is black. It drops down to naitve contrast of panel in more difficult scenes
My buddy who owns 85U7K counted 36x36=1296 dimming zones. It is exactly the number of zones 85U8K has.
With the U7K that’s usually not the case. Since it has a lot more zones and a more sophisticated local dimming algorithm.
IMO the way to understand the U7K algo is that the worst case situation (VA native) basically never happens. However the best case (pure black bars) is also hard. It almost always stays like a very very very high contrast VA. Something like 100k:1 contrast ratio.
I got my 85U7K. First impressions are very good. Fantastic picture quality overall. Plenty of brightness, very good black levels, no blooming ( at least I didn't see yet).
There's some gamma deviation out of the box. Some inaccuracies with white balance that should be fixed but nothing special.
I am interested in U7K 65 inch. Now they have increased the price by Rs 5000 to 84999. Is there any offline dealers in Bengaluru with competitive pricing. I also would like to know their quality of service in bengaluru.
@akarma Do you mind sharing how much did you get 85U7K for, and from where? I see the prices have gone up dramatically on online portals in the past few months.
hi folks,
my 7 year old 55 inch LG nanocell got kaput, suddenly saw lines and flickering all over the screen since one month, its a off time to purchase a TV but couldt help, should i go for 65U7K for a price of 70ishK right now on flipkart after exchange price to my LG TV. or should i go with 3 year old Mi Q1 75 inch for the price of 90k after the exchange and card offers
As someone who owns a master series QD-OLED
Long time @lightgamer - You finally got a QD OLED (>> WOLED) ? Which one? Is there a thread / article about this and your experience?
as well as various other miniLED displays with 1000+ dimming zones,
Which ones are these?
I'm still impressed by this TV. It's so good that for most of our viewing we prefer the U7K over the A95K because the size difference is bigger than the PQ difference.
My uncle got a 75" Sony which might be one of similar series. Whats your Hisense size (not in your sig)?
Can you check & compare something for me wrt Sony vs Hisense as I might follow your steps on HiS?
I got the 65” Sony A95K in 2022 Diwali season.
This tv doesn’t need a thread. The TV is about as perfect as it gets.
I have the Samsung Odyssey Neo G7 monitor with 1196 zones, and the MacBook Pro 16” with 2500.
My Hisense is 85”
Sony is better, obviously. OLED is OLED.
Haha! I guess this QD OLED helped you skip the entire W-OLED pondering you were doing a while back right?
And instead of 42" LG OLED you got this.. Nice.
I am looking into this thanks to you, and debating between which 43" will become my next monitor.
Hence, need your inputs a bit.
My Hisense is 85”
I wasnt meaning comparing their screens.
I like the convenience to use Airplay 2 from iPhone and iPad quite a bit, so my desktop Monitor/ TV might need to have that.
Sometimes I like having a massive screen to go through the iOS stuff to find/ clear out data in my screenshots etc.
As per Apple website like, some of the non premium brands (outside of LG Sony etc) like HiS & TCL also have some models in that foray.
Hence, I wanted to compare the AirPlay 2 video responsiveness between Sony & HiS as some random reddit post said it wasnt responsive. Cant find any data or video to verify that.
(I can try to test it on my uncles Sony but wouldnt have your comparative ability).
Think I could bother you with some of my use cases here?
