Santanu Roy
I am looking at buying a 5.1 channel AV receiver + a 5.1 speaker system, to replace an old HTIB from Sony. Need to connect a HD set-top box, a DVD player, and other players to this receiver (the first 2 through HDMI). Budget between 40 and 50k.
Have seen Yamaha HTR 3064 (connected to Jamo 5.1 speakers) and Harman Kardon AVR 134 (connected to JBL Cinema 300 speakers).
Personally preferred the Harman / JBL combination, but later found out that the AVR 134 carries only video on the HDMI channels (so you need to connect the audio separately, and thats a lot of hassle). Also the Yamaha receiver allows auto callibration of the speakers, depending upon the room size and speaker positioning, while the Harman receiver does not support this.
Can I go with the Yamaha HTR 3064, along with the JBL Cinema 300 5.1 speakers ? Would there be any mismatch, or the effects would be the same ?
Or should I try for 5.1 Yamaha speakers with the 3064 receiver ?
Is the HTR 3064 same as RX-V371 ? Is this the latest model available in India ? The yamaha website says that this has been discontinued. But all mega electronics stores, such as Reliance Digital only sells 3064 amongst Yamaha.
