5.1 Channel home theater for my LCD
shree123
Hello Guys,
Recently I bought Samsung LA40C550 LCD and I would like to connect my LCD to 5.1 channel home theater. Please throw some lite on how to connect LCD to home theater. Most of the LCD o/p 2.1 channel audio and if I connect 5.1 channel home theater will it o/p 5.1 or not? Also suggest me any good 5.1 channel home theater within 5K range.
Thanks,
Shreekant
LCDtv with coax/optical out only can connect digitally to HTibs.
You can connect 2ch out of LCD with analoge to Htib,but will get pseudo surr like prologic2.
Now to get true surr,you need 5.1 source like HD STB,DVDp.STB can directly connected to Htib & picture from LCD.same with DVDp.
But for 5k,you get only PC spk in that budget which can be used with analoge,but no true surr.
No pls.decide accordingly.
Please suggest me any good 5.1 channel home theater...
Shree123, if you are ok with chinese product. Totalmall has one F&D(fenda) 5.1 speaker system for 6500/-Rs . I dont know the tech specs but it sounded very decent and looks are also very nice and glossy.
for abt 10K, samsung HT-C450 is a good option.
its about 500 W RMS. plays and upscales dvd via hdmi.
it has an optical audio in:).. to
connect your tv's optical audio out (40C550 has it)
connect any bluray or dth hd boxes via hdmi directly to tv..
this way any 5.1 dig. audio from bluray/dth hd can be played in the HT..
hope this helps.:)
My brother bought a Panasonic HTIB with HDMI out and USB in for 8 K from Hypercity Goregaon Mumbai
Below average sound but had all inpits outputs we need.
Will giive it's model no.
hope this helps.:)
Hi josedandrew, Thanks for your valuable inputs, I want to play FullHD movies from my external hard drive through USB, in this case also i will get good 5.1 surround sound with samsung HT-C450 via HDMI cable?
well, a bit more clarity is required here.
you mean playing movies from your hdd connected via tv's usb port?
afaik, all digital audio to tv via hdmi or usb will be repeated via tv optical out.
HT-C450 can decode 5.1 from optical input (except HD audio). you can check formats supported at samsung website.:)
Yes josedandrew, I would like to play my movies from USB port not using DVD player.
As per my understanding from your post, using HDMI we need to connect from LCD to HTIB to get 5.1 channel audio effect. please correct me if i am wrong.
Samsung LA40C550 supports formats: AC3, AVI, MP4, VOB, MKV etc.
no, the hdmi on htib is to send video/audio to tv.
you can connect an optical dig. audio cable from tv to htib.
in theory optical audio can carry 5.1 DTS..
but i think it will carry only 2 channel stereo from tv.
to get around this problem u can either..
1) connect hdd to media player like WDTV and connect WDTV optical out to htib optical in.
2) connect hdd directly to htib usb. but check the video formats supported by htib via usb.
anybody pls. correct me if i am wrong:)
sadly the manual says, only 2 ch audio will be avlbl at optical out when any digital component is connected to tv via hdmi..(its a shame) i think same applies to usb too..
either you should settle for 2 ch audio from tv optical out or connect usb device via a media player or posisbly a bluray player which doubles as a media player and connect optical audio frm mediaplayer to htib.
htib itself can play avi (divx) and wmv sd formats throu its own usb. :)
So, I can buy Samsung HT-C450 HTIB and play movies via USB and connect TV using HDMI cable to get good PQ and 5.1 channel surround sound...
I don't think Samsung HT will support HD movies via USB..It is limited to few SD divx format only.. you will not be able to play hi-def movies..
