7.1 system setup
@OP: If I understand you correctly, you want to have casual movies/music experience at home, without doing much modification in your room. Well for that, I would suggest you go with a Marantz 5013 Avr + jamo s35 hcs 5.0 speaker + 10/12" sub. Reason for these items:
1. Marantz 5013 Avr : It have pre-outs for all 7 channels, so, you can add external amplification in the future if required.
2. Jamo S35 5.0: They are a pretty small, still powerful speaker and they can easily mount on walls or placed on desks. I am using them and found that they will be pretty suitable for your scenarios. Keep in mind, they are not the best sounding speaker for their cost, and compromises are made to get them that small design.
3. Sub: Those Jamo speakers lack base, so, a sub is a must with them.
Sorry All, had to be offline on this topic with family member home isolation and the tension around it. Just back from hibernation and hopefully close out.
This is what i got latest from the lone vendor :
7.1.2 Polk Audio package is what he has quoted:
Polk Audio TL-1600 5.1 Channel
Surround OWM3
Ceiling Speaker RP-60i
Denon 1600 AVR
Does it sound good?
Surround OWM3
Denon 1600 AVR
Does it sound good?
Welcome back, hope all is good.
Denon-1600h is good choice, it’s 7.2 AVR. Polk TL-1600 5.1 + RC60i (pair) should suffice.... that will cover all 7 channel with 1 subwoofer not sure the need for OWM3? What’s the price he is quoting for each equipment?
Polk audio TL-1600 5.1 Channel - 40000
Surround OWM3 - 17000
Ceiling Speaker RP 60I- 16000
Denon 1600 AVR - 48000
with ceiling mount, hdmi cable, power cable, speaker cable, installation , motorized 120" screen - it is coming to 160000. Is it a good deal in terms of equipment and cost?
Very good price on Denon 1600 AVR, thats the lowest i have heard on this model. Rest all are 1-2k plus from online price. Total - 1.21lac for the equipments. Around 39K for other accessories/installs which you have mentioned, it all depends on the various material (quality / Brand) of products which the dealer will be using. Will leave it to other FM to share their opinion who have built/installed their setup.
:cool:
That's too high for x1600 you should be able to get x2600h for say 5k more which would be better
The denon X1600h can be had for about 48k and the x2600h for about 55k. You are getting charged about 39-40k for installation which I dont think is right. Motorized screen should be about 14-15k and rest of the charges should not exceed 10k unless you are getting some top brands for power/hdmi/speaker cable. Also TL-1600 can be had for about 37-38k , have seen these prices listed directly so further negotiations should be possible
Thank you flux, sujith blaze, apbinu
I received revised quote -
Polk Audio TL-1600 - 37200 - So locking on this now
Denon x 1600 H - 48k - locking on this now
Ceiling Speaker RP 60i - 15100 - Can i lock down ?
Surround OWM3 - is this fine or should i go with any other model? - Latest quote is 16000
Other things:
HDMI Cable 10 mtrs - Bandridge - 6500
Ceiling Mount - 1+1 = 1800
Speaker cable 100 mtrs - 10000
Powercable 10 mtrs - 1000
120" motorized screen - 15500
installation - 5000
Other things:
installation - 5000
installation is generally free. I bought taga harmony 5.0 speaker from one dealer and denon 3600h avr from other and both offered free installation. Talk with your dealer for a free installation, else contact the polk/denon for installation.
i didn't want to go seperately and so gave all to one vendor. we need to do some cutting in false ceiling and pull wiring and all that. so thought it might be needed.
Well, although it's your decision to take, but 5k is not at all justified for HT installation, provided you are buying items worth 1.5L. I got a quote of 1k when I asked around a little with local audio technician for my 5.1.4 atmos setup installation. Try to negotiate with him and ask for free installation. I think he can do that atleast, and you can spend that money in buying something better or just save it.
Thanks for your concern. I appreciate the callout. Will see if i can cut some.
Other things:
installation - 5000
My friend recently installed a 7.1.2 setup and we used finolex 2.5 sq mm speaker cable which is 12 gauge for rs 3800 (100 mtr). The results were quite good. You can even go for 1.5 sq mm which is 2400 only.
You can save min 6k on speaker cable alone and add that money to get a better avr 2600.
Regarding omw3 a fellow member was selling two pair on very reasonable prices, you can check that.
Vikas
