A DIY attempt for a TL Sub with some twist
Whooo.. What a way to integrate a sub.. Awesome..
Just curious.. I see you have placed the center speaker & other items, don't they vibrate at all ?..
I can barely feel any shake on the table, may be due to the TL design efficiency and there is more space to dissipate the energy. The vibration might be felt at higher gains but my entire house will also be shaking along :D. There is no need increase the gain more than 50% as per the current settings and that itself can be felt on my chest.
sub placement is the most tricky part.
many people fail miserably even after trying all possible placement positions in the room.
Your attempt doesn't have any other option other than placing below the tv.
And it worked for you !!!!
Your don't know how lucky your are bro !!!:D:D
Not really brother, I chose the particular design primarily because it's flexibility to place anywhere in the room. Please go through the below link which mention the same.
http://www.audioxpress.com/article/the-hideaway-tl-sub
Thanks guys for the encouragement, I can help with the design if anyone wants to give it a try.
