The 5770 is also supposed to pass HD Audio. I have not yet succeeded with either VLC nor with PowerDVD. I am planning to reinstall the OS on Monday, and take it step by step. If that does not work, I may have to overwrite the EDID of the AVR which is the last option. Tulli of AV Forum is an expert in that, and he has agreed to help.
How can you copy the BD folders into the HDD and play them? They have AACS encryption.
Are these pirated BDs?
OP i wonder why you still use PowerDVD. VLC/media classic player/KMPlayer also play BR Rips...
OP i wonder why you still use PowerDVD. VLC/media classic player/KMPlayer also play BR Rips. Infact windows 7 media center edition plays any format with ease. Works well with TVtuner/remote too.
Have you been able to bitstream HD Audio with any of these players over HDMI?
Benefit of PowerDVD and similar software is "One Stop Shop" solution for HD Video/ 3D as well as HD Audio.
I am getting confused with actual Hardware acceleration & many site suggests different ways. Is there really need to use ffdshow as its external codec for that? Without that will everything go fine?
KM Player does NOT play Blu-Ray at all. It plays the initial ads/menu and then hangs. It does not bit-stream audio at all.
Though VLC does play Blu-Ray, as has been explained above by many people, it is 'iffy' in many ways. In addition, it does not bit-stream HD Audio.
Of course, all these are on my system.
nah.. i actually don't have a digital set-up, using onboard sound with ATPs . . was curious about PowerDVD as i used to think its boatware![]()
I hope this Dts-HD is not downscaled as Dts(sd),I dont think so as D2X is capable of handling 192/24bit audio.
