Swara preamp and Poweramp. DAC was their top of the thiyaga dac. Speakers were a new, yet to be launched towers, still undergoing testing.Did you listen only to Swara or also Thiyaga?
MaSh
the boy is soon gonna have many portraits on his tableHaha. The boy is smitten!!
Raghu
Raghu
I agree and I am not even intending to replicate the same performance. Primary reason being, i do not have the budget to acquire rest of the components. It could be a goal, who knows.As you're blown away by the AP setup, I'd suggest you to replicate the entire chain in your place to check if you get the same feeling. I doubt just adding their preamp or poweramp or DAC to your existing setup will make the same impact.
including the room !! just kidding.As you're blown away by the AP setup, I'd suggest you to replicate the entire chain in your place to check if you get the same feeling. I doubt just adding their preamp or poweramp or DAC to your existing setup will make the same impact.
It is also high gain so works well with normal to low gain power amps.
Would anyone have an idea whether the AP Swara tube pre will pair well with Parasound A21 power amp? I am looking for a tube preamplifier to go with the Parasound power amp. My speakers are Monitor Audio 500 towers. Thanks in advance.
There are power amps which by design are high gain. Meaning, they reach clipping point faster than a low gain design. However, I agree that it is the preamplifier which controls gain in most circumstances.square_wave, 'Low gain power amp' : you mean low output power amp? . Thank you.
Since you are based in Bangalore, ask AP if a home demo is possible.Would anyone have an idea whether the AP Swara tube pre will pair well with Parasound A21 power amp? I am looking for a tube preamplifier to go with the Parasound power amp. My speakers are Monitor Audio 500 towers. Thanks in advance.
Thanks MaSh for the invite! I am located near Hennur. I will PM you for your location.Where in Bangalore are you located? If anywhere close to Whitefield, you could come over anytime next week. I should have my AP Preamp by then.
MaSh
Yes I don't think they should have any problems. They have a great setup there to audition.Hi, MaSh, nice to hear about your trip at AP. Would they be accomodating to arrange for a listen to the pre and mono blocks? How did their Poweramp sound? Thanks.
Was in touch with them, they even offered to send the products to my place for an audition. Super!Yes I don't think they should have any problems. They have a great setup there to audition.
MaSh
