Again the modern Pro-Audio drivers are winners
Someone tried Both Tannoys and Beymas with 15 and 25 dB dampenings in order to hear the large signal distortion from both of the drivers, here are the results.
Source
Now its clearly evident that even at high volume listening the Beymas kept the distortion profile much lower when compared with Tannoys.
So just put the ratio in perspective, you will see that how much lower the distortion is in the modern drivers when it comes to low level listening.
Ranjeetrain, power handling of new drivers will be better than vintage drivers. This is of great importance in pro audio. May not be that relevant in home audio. Most of the new cone materials has been designed for better power handling.
I then chose the somewhat more expensive Beyma drivers and haven't had a single regret about it. They are fantastic!. Compared to a pair of Tannoy 15' 385 Golds (the model from the Westminister horns) they sound much better in any way I can think of. The Tannoys sound great at low volumes but driven to loud volume they get an unpleasant, distorted sound, IMO. The Beymas still play clean and undistorted long after my ears are distorting. This was verified by turning up the volume until I heard distinct distortion, then put in my full-range linear musicians ear-plugs - tried both the 15 and 25 dB dampenings - The distortion was clearly an artefact of my ears, not the speakers) . This was done at about 5 meters listening distance. You would need a VERY large room to ever be able to run these babys to within their limit.
Source
