Vivek Batra
I recently bought Denon x4500H with Klipsch RP-8000F and R-115 SW Subwoofer mainly for 2 channel application. I know most of the people here would disagree with this choice so is myself. I am not very happy with the sound of the system over all. My observation from the system is as below.
1. Tweeters overpowers mid range
2. At lower volume towers become very flat (-35db to -30 db)
3. Instruments separation is not very great.
4. Sounds seems clipped or feels under powered.
5. Sub woofer is quite good so no complains on that part
Not sure if its the Denon AVR or the Klipsch are are culprits here.
I want to invest in real good stuff for 2 channel only. My initial thoughts are going mono blocks as power amps and a matching pre amplifier. It would be nice to have sub outputs in pre amp.
Could you please suggest me any good pre and power amps that would go well with Klipsch ? I am open to replace the speakers as well with more musical speakers with good instrument as well as channel separation.
My Room size is 12*24
Listening position from the system 10 Feet.
Budget 8 Lacs
Looking to buy brand new stuff
Budget 8 Lacs
