Amp for JBL Control One
Experts,
Could you please recommend a good Amp for JBL Control One ( 8 Ohms, 100 W) speakers. Budget is max US $100. Planning to get the amp from US.
I think the best one with that budget would be Topping TP20. Look for a very long thread on this combination where people are very happy with this setup.
Till now I was using Topping TP20 with it, unfortunately it got damaged.
So I wanted to try some other combination.
@keith_correa: Thanks for input, I'll check it out.
@ghatgepatil:Amptastic & Temple Audio amps are not listed in the Amazon US site. Do you know any other US site?
Above budget but look at smaller amps from emotiva
mini x 100
fusion flex
