rohitmusic
LOL ..... don't want to spoil him. or rather spoil his ears.hyeah:
hyeah:
LOL.. now im really afraid im in search for that sound..
So will try my best to NOT hear into that never ending trap
"Let there be Peace....."
hyeah:
Klipsch with the Horn tweeter is going to sound way brighter so if it was used as a benchmark then the Paradigm's are going to sound warmer. .
It could be the reason .
Kittu.. Since you have the exact same speakers that the OP has. How would you describe the sound signature
Monitor 7s produce a very strong and forward sound. On their own they are a little lean on the bass extn ,nothing too bothering but definitely will push you to add a sub in future. The speakers are detailed , dynamic and fast too. There is a bit of lack of bass when compare to the PSB image series , but again what you pay is what you get. Add the sub and set the xover more than 80 (which is THX recommendation) they sound more full bodied. AVRs like Onkyo , Yamaha will make the experience more brighter , forward and at times little too hards n boomy. So probably adding something like NAD or marantz will be more sublime sound signature. However when I tried with NAD 326bee amp , vocals were way too loud and I was completely missing details. May be need to try with 350 and above series. I would say these are highpowered bookshelfs not really a big sized floorstanding speakers.
Again a lot of things depend on source, amplification , cables and room acoustics/placement. So best is to try out and let the speakers tell you more about them.
A tiny 8inch or a 10inch sealed or front ported sub will add the additional bass that is missing. Again its personal choice.
Actually we also heard the Klipsch along with the Paradigms.. and we definately found the Klipsch giving much "brighter" sound. So, it may very well be a relative comparison that we are makingIs it so?
I was more talking on the AS500 side, even the same case with yamaha avr.![]()
@rohitmusic: Why not let your ears be the best judge? Would love to host you anytime. I guess even Flash won't mind a Dark Forest brewed by yours truly over some auditioning?
What say?
Klipsch's are notoriously bright and gives me headache in minutes.
Are you into hard rock or metallica kind of sound? If yes, the paradigms will not suffice.
It may we be your room too.
Did you try the monitor audios?
BTW, do try out the Flash's Arcams. Never heard them but people's opinion is that its better than NAD and Marantz. He was planning to sell them. Not sure of the current status though.
What say?
Rohit, if you wanna listen to Monitor 9 with CA 650A then you can come to my place anytime.. you can bring you monitor 7 to see how they sound with CA..
I feel Paradigm is lil bright speakers.. Right now my setup is bright so just giving some time to these speakers with CA.. but again that's personal preference.. some people like bright sound.. if i feel later that CA is not a perfect match then I'll start looking for other amps to match with these speakers.. BTW m also in a queue to listen to these speakers with Flash's Arcam amp..![]()
Thanks Sagar, would definitely like to catch up with you to listen to this CA combination with the paradigms, will try to arrange my monitor 7s. Will keep you posted of the plan. Thanks for the kind inviation. Appreciate it!![]()
