Audio hiFi Accesories
magma
Here some accesories i have made over time for either my personal use or for members by request
All items below have been fabricated by me
Spikes
Type 1 : Dia 12mm solid SS marine grade with 3/8 inch threads.(Stands and Racks)
Type 2 : Dia 32mm Solid SS Double contoured SS spike (Racks) seen at the rear of the pic
Type 3 : Dia 32mm Solid SS spikes for Electronic Equipment
Spike Feet
Type 1 : Dia 20mm and 4 mm thick Solid SS locating feet
Type 2 : Dia 32mm and 4 mm thick Solid SS locating feet seen at the front portion of the pic
Type 3 : CNC turned Dia 32mm and 8mm thick Solid SS self locating feet
Footer
Here is a footer for very heavy stands/racks where one would like an alternative to spikes and spike feet
The design is modelled behind the old ceraball inards
Collars
Type 1 : Ball isolating collar set (Collar can be used with granite,Glass Plexi etc)
Type 2 : Collar for wood racks
SS caps
I have seen another thread from you on hi fi rack, I must say that you have a done a wonderful job. Keep up the good work. I hope I get to learn/ buy something from you.
Great Job Magma! I have one question - can the type 3 spikes be made in brass? If so what would the cost be vs SS.
Sid
Very Nice finish -great job .
I remember your help on my passive pre- thanks ( though way late)
Planning to order for a rack from you shortly
Pratim
Very nice.Now what about making them available to us?
George, of course they are available but as all quality things, must be expensive too:sad:
everything ive ever made is available to known members of this forum
I do not offer it outside since i dont take advance payments
Unless ofcourse its a real expensive request or the item is especially commisioned or modded so extremely that it cannot be of use to anyone else
Also since this is still a serious hobby i do take long in execution add to that the fact that im quite finicky about things myself.
i probably reject close to 20% of stuff done by my vendors
My lead time is what actually stops me from going commercial and drives many would be customers away
About the expense part
Im not cheap i agree
But there is good reason for that.My customers or work can attest to that
But let me assure you that i probably am cheaper than most high end imported comparable products
ALso rest assured i DO NOT compromise on material or labour.I do each job as if i build it for my personal use
i better stop talking or blowing my own horn lest i be pulled up for being a commercial member
@sidvee
anything can be made
hmm ..; i think i should use that as my, whats it called motto vision statement if i ever go commercial which i am seriously considering anyway
@sidvee
Having been a past customer of Magma - I can attest that his work is superlative - I would not have got a product for the price he offered, either imported or local, and the overall finishing was excellent.
Magma,
I will pm you on the equipment supports.
Sid
Hi all,
I recently purchased Spike bolts from Magma, and would like to say that the finish and quality were very good. I will post a pic of the same with my DIY speaker stands shortly.
N.Murali
As always they look fabulous...great work Magma. My friend is making the speaker stands for me, I hope its at least to some levels as yours as he is planing to go commercial with it :)
But let me assure you that i probably am cheaper than most high end imported comparable products ....
Ali made speaker stands of granite and SS and a hi-fi rack for me and shipped them to me at Kolkata. (The granite part was done locally as per his specifications) and the quality and the aesthetics has to be seen to be believed. They are truly unique products. Thank you Ali!
Manoj
@sidvee
hey sorry boss
your pedestals are taking a bit of time
My lathe shop has been a bit loaded so the spikes are getting delayed
will try and finish this week though
