Batery powered DIY CNC phono stage
Thanks Sachin, for sharing the component list for the CNC phono pre. Just wanted to check with you, can they be ordered online?
All components are available with www.digikey.in You can buy some parts locally,like toggle switch,op amp socket,9v battery connectors,Led,etc.Op amps,some capacitors and resisters are available with www.element14.in.I have included digikey part no in BOM for easy searching.Digikey shipping charges are vary much on higher side $40.I suggest you to opt shop n ship service for digikey.Please mail me if you have any problem regarding parts.
Sachin
Can we connect the o/p of this pre to another pre-amp (esp a tube pre)?
Sure! Why not? Its perfectly okay. During my testing I tried these with my TCC-754 (as non preamp input)as well as Tandberg TCA-3002 also. It worked perfectly.
Yes,I am planning to build Pass B1 preamp for the same reason.
^^ +1, I am also in same plan.
Is there anybody \ a group planning to procure the parts from Digikey. Please include me also, I am also looking for building one ASAP since my TT is lying idle for a long time and dont have a phono pre.
Hi Sajith,
There are some components available at element14,so custom duty can be avoided.Toggle switch,LED,battery connectors,Op amp socket,RCA plug,can be bought locally.Rest of the parts can be ordered from Digikey.It will save some custom duty.Please find below link for reference :
Shopping Basket | element14 India
There might be more parts available at Element14,you have to search for similar values.
Sachin
Hi Sajith,
Sachin
I have no idea about electronics and so finding a similar part from the available ones will be almost impossible for me.
There are two more people reubensm and Gvenu looking for parts,and I feel they are good in electronics:).Let me know If you find any problem,I will order for you.
Sachin
It seems some of the parts in digikey and elements14 are out of stock. DigiKey seems to be expensive as the available parts costs only 8$ and the shipping comes to 40$ flat. Is it recommended to buy the parts locally from SP road, are they of the same quality? I need to build one asap as my TT is idle for long time.
I have not started on the project yet, very busy with some official work and official travel. My guess is that we may be able to get away with reasonable quality on the resistors and caps. However, the quality of the OP Amp may vary. The international ones are better.
cmsajith,
I built this kit using the parts put together by omishra and sachin. I believe they sourced from both overseas and locally. My suggestion is to scourge SP Rd , if you are in Bangalore. You may get some of the better ones in Amar. However, putting on my DIY hat, I would say get the best you can from SP Rd and build your phonostage. You would be pleasantly surprised. The price differential may be worth it:)
HTH
cmsajith,
HTH
Hi below is the list - how we purchased the BOM.
Update:
I bought below part locally for 8 sets -
Resistors:
1 X P8.20KCACT-ND / RES METAL FILM 8.2K OHM 1/4W 1% / LED Loading Resistor
4 X P100CACT-ND / RES METAL FILM 100 OHM 1/4W 1% / Gain Resistor - Increased
4 X P150CACT-ND / RES METAL FILM 150 OHM 1/4W 1% / Gain Resistor - Std
2 X P18.0KCACT-ND / RES METAL FILM 18.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P2.20KCACT-ND / RES METAL FILM 2.20K OHM 1/4W 1%/ Noise Blocking Resistor
2 X P200CACT-ND / RES METAL FILM 200 OHM 1/4W 1% / RIAA Resistor
2 X P27.0KCACT-ND / RES METAL FILM 27.0K OHM 1/4W 1%/ RIAA Resistor
2 X P33.0KCACT-ND / RES METAL FILM 33.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P47.0KCACT-ND / RES METAL FILM 47.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P62.0KCACT-ND / RES METAL FILM 62.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P750CACT-ND / RES METAL FILM 750 OHM 1/4W 1% /RIAA Resistor
Capacitors:
4 X BC1084CT-ND / CAP .10UF 50V CERAMIC X7R 10% / Power Supply Filter
4 X 604-1061-ND / CAP ALUM 10UF 35V 20% RADIAL / Power Supply Filter
Accessories:
2 X CP-1413-ND / CONN RCA JACK METAL RED PNL MNT / Cheap RCA Jacks Red
2 X CP-1414-ND / CONN RCA JACK METAL WHT PNL MNT / Cheap RCA Jacks White
1 X 67-1107-ND / LED 5MM RED TRANSPARENT / Std Red LED
2 X ED90105-ND / IC SOCKET 8PIN .300 SOLDER TAIL / Op Amp Sockets
2 X 235K-ND / STRAP BATT ECON 9V T STYLE 4"LD / 9v Battery Connectors
1 X S114-ND / SW TOGGLE DPST 5A SOLDER LUG / On Off Switch.
Sachin will be ordering below from Digikey for 8 sets
Accessories and OP-AMP:
2 X CT2064-ND / SWITCH SPST GOLD 4 SEC / Input Loading Dip Switch
2 X AD823ANZ-ND / IC OPAMP JFET R-R DUAL LN 8DIP / AD823 Op Amps
Capacitors:
2 X P4518-ND / CAP .027UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4519-ND / CAP .033UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4521-ND / CAP .047UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4675-ND / CAP 1UF 50V STACK METAL FILM / DC Blocking
Resistors:
4 X RNF14FTD3K32CT-ND/ RES MF 1/4W 3.32K OHM 1% AXIAL/ Feedback Resistor
4 X 3.83KXBK-ND / RES 3.83K OHM 1/4W 1% METAL FILM/ RIAA Resistor
Final user need to buy this for themselves.
2 X P647-ND / BATTERY IND ALKALINE 9 VOLT
I hope this helps. Best luck. In this case those US 40.0$ shipping was shared among all participants.
Can we source the following parts locally which sachin had ordered from digikey?
Capacitors:
Resistors:
The .027/.033 caps were available last week at Chetan I think. Rest I have not checked. You just need patience these days at Sp rd. as I think the college kids have started on their projects and there are hordes of them at the shops competing for the shopkeepers attention. Those of us who have been there know this:D
Anyhow good luck. HTH
Reminds me of my younger days and not to forget the disgust on the store attender's face when I used to show up with a long list of resistors and capacitors. 1/4 watt resistors each used to cost 10 or 15 paise in those days. The store guys were more interested in customers who queued up to purchase assembled PCBs, etc.
Capacitors:
Resistors:
  • Loading switch must be of good quality with gold plated contacts as it comes in path of very very low signal from cartridge.
  • OPAMP must be same (manufacturer/part no. wise) wherever you get.
  • Caps from Panasonic (or WIMA or better) are must because different caps with same values sound different.
  • Those two resistances are very uncommon values which I could not get here in 1% MFR (metal film) type. [3.83K is must be accurate for frequency curve. 3.32K will change gain of OPAMP.]
