Batery powered DIY CNC phono stage
Cnc bom
Hi all,
All CNC parts are available with Element14.I am posting BOM with Element14 link:
2 X Opamps ANALOG DEVICES|AD823ANZ|IC, OP AMP, FET R/R DUAL 16MHZ | element14 India
4 X 3.83Kohm MULTICOMP|MCMF0W4DF3831A50|RESISTOR, 3K83 , 0.25W 0.5% 50PPM | element14 India
4 X 3.32K OHMhttp://in.element14.com/te-connectivity-holsworthy/h83k32bya/resistor-0-25w-0-1-3k32/dp/1751498
2 X CAP FILM 0.027UF 50VDC RADIAL PANASONIC|ECQV1H273JL|CAPACITOR, 27NF, 50V, 5% | element14 India
2 X CAP .033UF 50V STACK METAL FILM PANASONIC|ECQV1H333JL|CAPACITOR, 33NF, 50V, 5% | element14 India
2 X CAP .047UF 50V STACK METAL FILM
PANASONIC|ECQV1H473JL|CAPACITOR, FILM, 50V, 47NF | element14 India
2 X CAP 1UF 50V STACK METAL FILM PANASONIC|ECQV1H105JL|CAPACITOR, FILM, 50V, 1UF | element14 India
4 X CAP .10UF 50V CERAMIC X7R 10% VISHAY BC COMPONENTS|K104K15X7RF5TL2|CAPACITOR CERAMIC 0.1UF, 50V, | element14 India
4 X CAP ALUM 10UF 35V 20% RADIAL VISHAY SPRAGUE|515D106M035JA6AE3|CAPACITOR ALUM ELEC 10UF, 35V | element14 India
4 X RES METAL FILM 100 OHM 1/4W 1%KOA|MF1/4CC1000F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India
4 X RES METAL FILM 150 OHM 1/4W 1% KOA|MF1/4CC1500F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India
2 X RES METAL FILM 18.0K OHM 1/4W 1%MULTICOMP|MF25 18K|RESISTOR, 0.25W 1% 18K | element14 India
2 X RES METAL FILM 2.20K OHM 1/4W 1%KOA|MF1/4CC2201F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India
2 X RES METAL FILM 200 OHM 1/4W 1%KOA|MF1/4CC2000F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India
2 X RES METAL FILM 27.0K OHM 1/4W 1%MULTICOMP|MF25 27K|RESISTOR, 0.25W 1% 27K | element14 India
2 X RES METAL FILM 33.0K OHM 1/4W 1%KOA|MF1/4CC3302F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India
2 X RES METAL FILM 47.0K OHM 1/4W 1%KOA|MF1/4CC4702F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India
2 x RES METAL FILM 62.0K OHM 1/4W 1%MULTICOMP|MF25 62K|RESISTOR, 0.25W 1% 62K | element14 India
2 X RES METAL FILM 750 OHM 1/4W 1%MULTICOMP|MF25 750R|RESISTOR, 0.25W 1% 750R | element14 India
2 x DIP SWITCH SPST Goldhttp://in.element14.com/multicomp/206-4str-p/switch-dil-4way/dp/1182360(Please confirm specifications before buying)
Other remaining non critical parts can be bought locally:
2 X 9V Batteries
2 X 9V Battery connectors
2 X Op amp Socket
1 X TOGGLE DPST switch
4 X Chassis mount RCA jacks
1 X LED
Sachin
Is Element14 a B2B portal? Its asking for Sales Tax Registration Number for registering an id... If we dont have, its providing KitsnSpares portal to buy. But some of the parts from KOA are not listed in that site. Also price seems to be higher than E14. Also for some of the parts' min order quantity is 50. So, is it recommended to buy those parts locally?
Hi Sajith,
We have to buy from K&S.Prices are at par with E14.There are some res. min quantity is 50.You can buy metal film res. of same specifications from a local store.
Sachin
Hi Sachu
So far all going great with CNC Phono stage, really enjoying it a lot!
however the battery drain is proving to be costly.. you mentioned earlier about connecting some lantern batteries.. how do i do this from a n00b perspective :P
Thanks!
Hi Sachu
Thanks!
From that headache I planned something interesting here. So far all 12 people confirmed it w/o transformer included. If somebody backs out then contact Sachin. I am not going to use my phono stage on battery.
Also Sachin mentioned that 2 X 28 Rs Eveready red battery is doing great for him. Why to spend 2 X 140 each time.
As an aside, last week when I went to the local market, I picked up some chinese 9v battery. Already 30 hrs gone and doing well. Not using LED.
Cost 10Rs. each...Of course no guarantee that the next pair will behave same. Who cares....10 v/s 140 !!!!
You are right! I already conveyed this to Sachin that those blue batteries are also doing great for low discharge. Just verify that it has black bottom and expiry printed on that.
Hi Sachu
Thanks!
Hi Tek,
I am using cheap Everreay 9v batteries(INR 28 each).It is giving me 36+ hours of listening time.I am going to try regulated +/-15power supply for CNC.If everything works well will order more pcbs for power supply else will return to batteries as I really like them on CNC.
Sachin
Ordered the parts in KitsnSpares, but the following are not available.
2 X RES METAL FILM 18.0K OHM 1/4W 1% (MULTICOMP|MF25 18K|RESISTOR, 0.25W 1% 18K | element14 India)
2 x RES METAL FILM 62.0K OHM 1/4W 1% (MULTICOMP|MF25 62K|RESISTOR, 0.25W 1% 62K | element14 India)
2 X RES METAL FILM 750 OHM 1/4W 1% (MULTICOMP|MF25 750R|RESISTOR, 0.25W 1% 750R | element14 India)
2 x DIP SWITCH SPST Gold (MULTICOMP|206-4STR-P|SWITCH, DIL, 4WAY | element14 India)
4 X RES METAL FILM 100 OHM 1/4W 1% (KOA|MF1/4CC1000F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India)
4 X RES METAL FILM 150 OHM 1/4W 1% (KOA|MF1/4CC1500F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India)
2 X RES METAL FILM 2.20K OHM 1/4W 1% (KOA|MF1/4CC2201F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India)
2 X RES METAL FILM 200 OHM 1/4W 1% (KOA|MF1/4CC2000F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India)
2 X RES METAL FILM 33.0K OHM 1/4W 1% (KOA|MF1/4CC3302F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India)
2 X RES METAL FILM 47.0K OHM 1/4W 1% (KOA|MF1/4CC4702F|RESISTOR, METAL FILM, 0.25W, 1 | element14 India)
plus the non critical parts listed.
Sent you PM
Hi Sajith,
All the resisters can be found in local market,only Dip switches are not available.
Sachin
