sachu888
Hi Joshua,
Sent you a mail.
Sachin
Sent you a mail.
Sachin
Hi Joshua,
Sent you a
Thanks, Sachin. Will make the changes tonight. I am not used to using batteries so I often forget to remove them, and the next time I want to play music batteries are already drained! The on/off switch is a must.
boy, you leave a trail![]()
Life is too short. I'm belatedly learning as much as I can, and hopefully, in the process, improving my audio playback without burning a huge hole in my pocketAlso, it's a lot of fun.
That's why my projects are never ending.![]()
Hi Joshua,
I am using DPST switch.You got the correct DPDT switch.Please find below pic for your switch.You can leave upper or lower terminals,but middle should be used.
Sachin
HI Guys, Just for my knowledge, how long does the battery lasts ?
Just completed OPS and will power up CNC this Saturday with OPS
Any suggestion as to what should be the Ideal supply voltage to CNC?
OPS has option from +/-9 Volt to +/-15Volt
regards,
Vipin
One of my friends a tv mechanic built it for me.However when i connected it is not sounding right.There is some sort of hum.Is it some sort of grounding problem? My TT has a ground wire and when I touch it to the screw with which the board is connected to a primitive box the humming changes.
Please take a look and diagnose the problem for me.
ImageShack
http://imageshack.us/photo/my-images/855/dsc0006wh.jpg/
http://imageshack.us/photo/my-images/401/dsc0004lg.jpg/
Thank you.
ImageShack
Thank you.
CNC works on dual Supply, +9, 0, -9. therefore you need to connect two 9 volt batteries.
Also ensure that Turntable Earth is always connected to the CNC earth.
Vipin
