Batery powered DIY CNC phono stage
Good initiative Sachin. The person whom I'm working with on my project keeps buying stuff from digikey. So, let us work on a deadline. Even if numbers are less, we can work this out as he would order our components along with those of his. If you can get the gerber file of the PCB from Hypnotoad, I can organise to make very good quality PCBs even in small quantities. Let me know. Mods, to attract more eyeballs, could we have some space on the home screen like the group buy of speaker stands of Magma etc. If some amount needs to be paid to HFV, all those participating can share the expenses.
Thanks Capt.
Its a nice idea.I have already got file for PCB making and have a BOM for CNC.Please let me know about PCB's if they are good quality and cost effective.PM me your mail id I'll send you the PCB file.
Sachin
Count me in guys. I am looking for a simple DIY project to start learning basics and I need another Phono stage too. But friends, I need bit of support here as I do not know much about electronics :(. I can solder simple stuff, thats about it.
Hi Santosh,
Only soldering is required for this project,no worries.
Sachin
Hi, Sachin, sending you a PM.
Hey Santhosh, George knows someone who is a professional electronics guy. This must be a 15 minute job for him.
Group buy update for CNC
HI all,
I have a tentative list of members for group buy CNC:
1.Capt.Rajesh
2.Ommishra
3.Santosh
4.Rajivmurli
5.Quad
6.Tek
7.Bhaskar
Please let me know if I have missed any name.
Sachin
Re: Group buy update for CNC
HI all,
1.Capt.Rajesh
2.Ommishra
3.Santosh
4.Rajivmurli
5.Quad
6.Tek
7.Bhaskar
Sachin
Hi Sachin,
I don't think mods have seen this thread. To attract more eyeballs, it would be prudent to put a ad link in the home page. Why don't you take up with them?
Just a suggestion. What do you feel?
Rajesh
Hi Sachin,
Rajesh
I feel we can go ahead with this small group buy of 10-12 people.Later If we get a good response can put an official ad.
Sachin
Got two more resistances on farnell which are non easily available :clapping:
3.32K OHM and 3.83K OHM
MULTICOMP|MCMF0W4DF3831A50|RESISTOR, 3K83 , 0.25W 0.5% 50PPM | element14 India
TE CONNECTIVITY / HOLSWORTHY|H83K32BYA|RESISTOR, 0.25W, 0.1%, 3K32 | element14 India
Best regards
Rajeev Murali
Hi Rajeev,
All components are available with Digikey with less or similar cost.We have a BOM with Digikey part number.It would be cheaper if we buy all components from one company.
Sachin
Hi Rajeev,
Sachin
Yes, Otherwise shipping will be paid more times for least components. Other thing, if we get hold of premium caps for required value then it will be good. [No point in saying that ceramic caps change capacity wrt voltage difference they are facing. This colors the audio signal. Hence start using polysterene etc. This is no good reason to use polysterene caps]
I agree.........
regards
Rajeev Murali
Hi all,
Here is part list for CNC :
Quantity Digikey Part Number Description Reference
2 X P4518-ND / CAP .027UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4519-ND / CAP .033UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4521-ND / CAP .047UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4675-ND / CAP 1UF 50V STACK METAL FILM / DC Blocking
4 X BC1084CT-ND / CAP .10UF 50V CERAMIC X7R 10% / Power Supply Filter
4 X 604-1061-ND / CAP ALUM 10UF 35V 20% RADIAL / Power Supply Filter
2 X CP-1413-ND / CONN RCA JACK METAL RED PNL MNT / Cheap RCA Jacks Red
2 X CP-1414-ND / CONN RCA JACK METAL WHT PNL MNT / Cheap RCA Jacks White
2 X AD823ANZ-ND / IC OPAMP JFET R-R DUAL LN 8DIP / AD823 Op Amps
2 X ED90105-ND / IC SOCKET 8PIN .300 SOLDER TAIL / Op Amp Sockets
1 X 67-1107-ND / LED 5MM RED TRANSPARENT / Std Red LED
1 X P8.20KCACT-ND / RES METAL FILM 8.2K OHM 1/4W 1% / LED Loading Resistor
4 X P100CACT-ND / RES METAL FILM 100 OHM 1/4W 1% / Gain Resistor - Increased
4 X P150CACT-ND / RES METAL FILM 150 OHM 1/4W 1% / Gain Resistor - Std
2 X P18.0KCACT-ND / RES METAL FILM 18.0K OHM 1/4W 1% / Input Loading Resistor
2 X P2.20KCACT-ND / RES METAL FILM 2.20K OHM 1/4W 1% / Noise Blocking Resistor
2 X P200CACT-ND / RES METAL FILM 200 OHM 1/4W 1% / RIAA Resistor
2 X P27.0KCACT-ND / RES METAL FILM 27.0K OHM 1/4W 1% / RIAA Resistor
2 X P33.0KCACT-ND / RES METAL FILM 33.0K OHM 1/4W 1% / Input Loading Resistor
2 X P47.0KCACT-ND / RES METAL FILM 47.0K OHM 1/4W 1% / Input Loading Resistor
2 X P62.0KCACT-ND / RES METAL FILM 62.0K OHM 1/4W 1% / Input Loading Resistor
2 X P750CACT-ND / RES METAL FILM 750 OHM 1/4W 1% / RIAA Resistor
4 X RNF14FTD3K32CT-ND / RES MF 1/4W 3.32K OHM 1% AXIAL / Feedback Resistor
4 X 3.83KXBK-ND / RES 3.83K OHM 1/4W 1% METAL FILM / RIAA Resistor
2 X CT2064-ND / SWITCH SPST GOLD 4 SEC / Input
Loading Dip Switch
2 X P647-ND BATTERY IND ALKALINE 9 VOLT
2 X 235K-ND / STRAP BATT ECON 9V T STYLE 4"LD / 9v Battery Connectors
1 X S114-ND / SW TOGGLE DPST 5A SOLDER LUG / On Off Switch.
It includes all parts minus case.I am waiting for CaptRajesh for PCB confirmation, we can order above components once we get the confirmation on PCB.
Sachin
This is my thought which could reduce cost further shipping-wise/quality-wise. Anyway I am open for what everybody decides. Please give a thought on this.
Must have:
2 X P62.0KCACT-ND / RES METAL FILM 62.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P750CACT-ND / RES METAL FILM 750 OHM 1/4W 1% /RIAA Resistor
4 X RNF14FTD3K32CT-ND/ RES MF 1/4W 3.32K OHM 1% AXIAL/ Feedback Resistor
4 X 3.83KXBK-ND / RES 3.83K OHM 1/4W 1% METAL FILM/ RIAA Resistor
2 X CT2064-ND / SWITCH SPST GOLD 4 SEC / Input Loading Dip Switch
Can be procured locally:
Capacitors (Generic common values):
Resistors(Generic common values):
2 X P18.0KCACT-ND / RES METAL FILM 18.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P2.20KCACT-ND / RES METAL FILM 2.20K OHM 1/4W 1%/ Noise Blocking Resistor
2 X P27.0KCACT-ND / RES METAL FILM 27.0K OHM 1/4W 1%/ RIAA Resistor
2 X P33.0KCACT-ND / RES METAL FILM 33.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P47.0KCACT-ND / RES METAL FILM 47.0K OHM 1/4W 1%/ Input Loading Resistor
Optional/Non critical (if anybody has different plans to power up/integrate):
2 X P647-ND / BATTERY IND ALKALINE 9 VOLT
