Batery powered DIY CNC phono stage
Optional/Non critical (if anybody has different plans to power up/integrate):[/QUOTE]
IMO the above could be an individual choice/optional.
Sachin
Hi Sachin,
In the morning I thought I saw your post stating that you are awaiting confirmation from me regarding the PCBs. I wanted to reply to that post but it went missing!! Are posts getting deleted here?:eek::annoyed::mad:
Hi Sachin,
NO Sir,
It is there in post#59.
Sachin
Hi Santosh,
Only soldering is required for this project,no worries.
Thats good, eagerly waiting for this to kick start.
Hi, Sachin, sending you a PM.
Hey Santhosh, George knows someone who is a professional electronics guy. This must be a 15 minute job for him.
Yup Philip is very good.
But I would like to try this on my own. I actually feel left out when you guys talk tech stuff about rating of resistors, capacitors etc but not this time around. I am looking forward to the learning experience:).
Hi Santosh,
PL follow this guide for soldering
http://www.tvbgone.com/images/mfaire/soldercomic.jpg
another good video
How to Solder : CuriousInventor Guides
Sachin
This is my thought which could reduce cost further shipping-wise/quality-wise. Anyway I am open for what everybody decides. Please give a thought on this.
Must have:
Can be procured locally:
Capacitors (Generic common values):
Resistors(Generic common values):
Thanks for ur breakup. I was also thinking on the same line but didn't get time to visit market meanwhile to check availability of the parts. Also for the first time assembly, using Digikey parts will give extra bit of confidence as it is already done by Sachin using same materials.
Is 'Keltron' caps are as good as 'Panasonic'? Bcos in Calcutta it's very highly recommended. What r the other good brands fr caps & resistors available in India?
Thanks & brgds
Bhaskar
I am waiting for CaptRajesh for PCB confirmation, we can order above components once we get the confirmation on PCB.
Hi Sachin, it was nice interacting with you over telephone yesterday. Hope there is some progress of the PCB part.
Yes I'm, told they are; I had recently restored a vintage Luxman amp and all the old caps in the tone control boards were replaced with Keltron ones. The amp sounds very good now.
PCB update
Hi all,
Today I went to a local PCB manufacturing unit.They have shown me some samples,which were at par with my CNC pcb.The minimum quantity was 10 so I ordered. The cost of each PCB is INR 70-75 including initial making cahrges and tax.He promised to deliver PCB's on Friday.
Sachin
Hi Sachin
I'm still in for this, but by when would you need the money from my end, and what is the total cost to me?
Also, if someone in Mumbai knows anyone who can help me to put this together, I would be very grateful. I am quite bad at DIY stuff, and I don't want to break a part or something and ruin the whole project! :P Although it seems like a really fun thing to try out, I don't want to mess it up :-0
Tek
Hi Sachin
Tek
I will PM you regarding money.Total cost would be in between 2500-3000 depending upon no of members for group buy and custom duty.It will include all parts and PCB, minus case.I have put my PCB in a wooden Jewelry box which I bought it from a handicraft exhibition in RS 200.You can contact Omishra as he offered building this kit for you.
Sachin
Here is my Digikey Invoice:
Name on Card Sachin A Nigudkar
All prices are in US dollars.
Index Quantity Part Number Description Customer Reference Backorder Quantity Unit Price Extended Price
1 2 P4518-ND CAP .027UF 50V STACK METAL FILM 0 0.34000 $0.68
2 2 P4519-ND CAP .033UF 50V STACK METAL FILM 0 0.29000 $0.58
3 2 P4521-ND CAP .047UF 50V STACK METAL FILM 0 0.27000 $0.54
4 2 P4675-ND CAP 1UF 50V STACK METAL FILM 0 0.68000 $1.36
5 4 BC1084CT-ND CAP .10UF 50V CERAMIC X7R 10% 0 0.36000 $1.44
6 4 604-1061-ND CAP ALUM 10UF 35V 20% RADIAL 0 0.30000 $1.20
7 2 CP-1413-ND CONN RCA JACK METAL RED PNL MNT 0 1.32000 $2.64
8 2 CP-1414-ND CONN RCA JACK METAL WHT PNL MNT 0 1.32000 $2.64
9 2 AD823ANZ-ND IC OPAMP JFET R-R DUAL LN 8DIP 0 7.05000 $14.10
10 2 ED90105-ND IC SOCKET 8PIN .300 SOLDER TAIL 0 0.99000 $1.98
11 1 67-1107-ND LED 5MM RED TRANSPARENT 0 0.42000 $0.42
12 1 P8.20KCACT-ND RES METAL FILM 8.20K OHM 1/4W 1% 0 0.15000 $0.15
13 4 P100CACT-ND RES METAL FILM 100 OHM 1/4W 1% 0 0.15000 $0.60
14 4 P150CACT-ND RES METAL FILM 150 OHM 1/4W 1% 0 0.15000 $0.60
15 2 P18.0KCACT-ND RES METAL FILM 18.0K OHM 1/4W 1% 0 0.15000 $0.30
16 2 P2.20KCACT-ND RES METAL FILM 2.20K OHM 1/4W 1% 0 0.15000 $0.30
17 2 P200CACT-ND RES METAL FILM 200 OHM 1/4W 1% 0 0.15000 $0.30
18 2 P27.0KCACT-ND RES METAL FILM 27.0K OHM 1/4W 1% 0 0.15000 $0.30
19 2 P33.0KCACT-ND RES METAL FILM 33.0K OHM 1/4W 1% 0 0.15000 $0.30
20 2 P47.0KCACT-ND RES METAL FILM 47.0K OHM 1/4W 1% 0 0.15000 $0.30
21 2 P62.0KCACT-ND RES METAL FILM 62.0K OHM 1/4W 1% 0 0.15000 $0.30
22 2 P750CACT-ND RES METAL FILM 750 OHM 1/4W 1% 0 0.15000 $0.30
23 4 RNF14FTD3K32CT-ND RES MF 1/4W 3.32K OHM 1% AXIAL 0 0.15000 $0.60
24 5 3.83KXBK-ND RES 3.83K OHM 1/4W 1% METAL FILM 0 0.12600 $0.63
25 2 CT2064-ND SWITCH SPST GOLD 4 SEC 0 0.76000 $1.52
26 2 235K-ND STRAP BATT ECON 9V T STYLE 4"LD 0 0.65000 $1.30
27 2 P647-ND BATTERY IND ALKALINE 9 VOLT 0 1.98000 $3.96
28 1 S21B-ND SW TOGGLE DPST 5A SOLDER LUG 0 7.19000 $7.19
Subtotal $46.53
Shipping Estimate
Sales Tax $4.13
Total unknown
Sure! I can. PM me if you needed that help.
Sachin,
As I mentioned, please think on these item for local procurement at least. Shipping charge of 9V alkaline battery and local RCA connectors can be saved.
Quality won't matter for these except item 10 which is not gold plated. If required I can purchase these for everybody. see item wise max price here -
7,8 - Rs 8 each/-
10 - Rs 5 each
11 - Rs 1 each
26 - Rs 5 each
27 - Rs 140 x 2 , 9V alkaline batteries are locally available from Duracell and Energizer. No point in importing and increasing weight of international shipment.
28 - Rs 25 Max (worst case)
also the item I told can be procured locally - wont cost more than 100 Rs. Still I say caps and semiconductors are okay if imported. Let me know.
Also I never charged in custom duty due to the fact that I always kept requirement list short.
Sachin,
7,8 - Rs 8 each/-
10 - Rs 5 each
11 - Rs 1 each
26 - Rs 5 each
27 - Rs 140 x 2
also the item I told can be procured locally - wont cost more than 100 Rs. Let me know.
Om
HI Om,
Its a good price.Can you procure the above items for group,because I don't have much choice in Nasik.
Sachin
Can these also be procured locally:
Quote:
Quantity Digikey Part Number Description Reference
2 X P4518-ND / CAP .027UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4519-ND / CAP .033UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4521-ND / CAP .047UF 50V STACK METAL FILM / RIAA Capacitor
2 X P4675-ND / CAP 1UF 50V STACK METAL FILM / DC Blocking
4 X BC1084CT-ND / CAP .10UF 50V CERAMIC X7R 10% / Power Supply Filter
4 X 604-1061-ND / CAP ALUM 10UF 35V 20% RADIAL / Power Supply Filter
1 X P8.20KCACT-ND / RES METAL FILM 8.2K OHM 1/4W 1% / LED Loading Resistor
4 X P100CACT-ND / RES METAL FILM 100 OHM 1/4W 1% / Gain Resistor - Increased
4 X P150CACT-ND / RES METAL FILM 150 OHM 1/4W 1% / Gain Resistor - Std
2 X P18.0KCACT-ND / RES METAL FILM 18.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P2.20KCACT-ND / RES METAL FILM 2.20K OHM 1/4W 1%/ Noise Blocking Resistor
2 X P200CACT-ND / RES METAL FILM 200 OHM 1/4W 1% / RIAA Resistor
2 X P27.0KCACT-ND / RES METAL FILM 27.0K OHM 1/4W 1%/ RIAA Resistor
2 X P33.0KCACT-ND / RES METAL FILM 33.0K OHM 1/4W 1%/ Input Loading Resistor
2 X P47.0KCACT-ND / RES METAL FILM 47.0K OHM 1/4W 1%/ Input Loading Resistor
Sachin
Sachin
Sure, Why not? I can go to market on Wednesday and do the shopping. Let me know total requirement. Then you can order remaining. What do you say?
I really miss Bangalore SP road. Vishal Electronics used to have all these values one stop. Any Bangalorian can still help.
Thanks Om,
I will let you know the quantity on Tuesday.
Sachin
Guys add me also to the list.
I'd love a phono stage since my AVR cant take phono inputs.
I am in the same boat as Tek though.
Mr. Mishra, if its fine with you, do you mind putting this together for me as well? Would be much obliged.
How do we go about transferring the money over to you Sachin?
