thanks for your valuable suggestions.
how to start upgrading my pc.i know i am asking too much info.. sorry.
with my exiting set up how to take it forward,like buying what next ..
could you give me an info of what to buy and options...
thanks.
OK I am going to assume you are on a budget. If you have an unlimited budget then the sky is the limit.
As far as upgrading your PC is concerned, you have to understand that you will have to go in for a completely new set-up. Your motherboard and processor are Socket 478 based and hence are outdated. Your RAM is probably DDR1 so that will also have to be replaced. The only thing that you can retain from your original set-up would be the keyboard/mouse and speakers. For other components like PSU (power supply) I recommend you to go in for a new one, unless your existing one is really good.
The prices I have listed are as per
techshop.in. They are a fairly good indicator of prices though you may be able to get the same thing for slightly lesser if you buy locally. So here goes:
Motherboard XFX 630i 7100 (or 7150) approx. 3200/- (recommended because it has a good onboard IGP, as well as having an HDMI port on the motherboard. So no need to go in for a separate graphics card as you can connect directly to your HDTV)
Processor: Intel Core 2 Duo E7500 Processor approx. Rs 5654/-
RAM: Corsair XMS2 1GB DDR2 800MHz CM2X1024-6400 approx. Rs. 1802/- (sadly the cost of DDR2 RAM seems to have gone up in recent times) get 2 sticks!!!
PSU: FSP SAGA II 500 500W Power Supply approx. Rs. 2253/-
Case: Cooler Master Elite RC 310 RC-310-RKN1-GP approx. Rs. 1766/-
And I recommend getting a wireless USB mouse/keyboard combo from Logitech. approx. Rs. 1500/- (there are some iBall wireless combos which sell for even less)
This is a rough estimate of what an upgrade will cost you. Do note that this is an Intel based set-up. If you choose to go the AMD way things might work out even cheaper. In the latter case you might go for
Processor: AMD Athlon II X2 250 Processor (3.0 Ghz) approx. Rs. 3483/-
Motherboard: Biostar TA690G AM2 Motherboard approx. Rs. 3210/- (this board might actually be a real great deal. It has 4 RAM slots and appears to have an HDMI port on the motherboard with an Onboard Video Chipset ATI Radeon Xpress 1250.
The RAM and other items can work on both platforms so remain the same.
