Best 5.1 speakers within Rs.60000
Fair deal, craford market, ashoka hall complex.
ph - 43444786, Ask for Ashraf. Tell him Hussain's given his reference. Bargain well. Avoid imran or Suleman, they wont leave room or opportunity to bargain.
Also they will try to push for pioneer. Pioneers are good, i suggest you take a demo there. I personally preferred and got the yamaha.
Hey Buds, I am new here ... and I have finalized on Denon 1713 ... Can you tell me where I can get the best price of this AVR ...
ok spoke to imran, as ashraf wasnt there ... and they gave a final price for the 1713 for 30K ... is that good enuf?
Now I am lost for the speakers ... my budget is around 60K including the subwoofer ... they suggest focal, but that is out my reach ... what about Jamo s606 with sub 260 or focal sib n cub 5.1 or morell soundspot 5.1 or finally mirage mx 5.1 all in the range of 60k or so ... i will audition ofcourse ... but wanted some suggestions first ....
i mainly listen to music 50%, movies 25% and balance hd channels ...
do suggest from the above or anything u personally think i shud go for ...
cheers
i was given a 28.5k quote. That too without any bargaining.
I personally dont like focal. I would pick up the mirage or paradign cinema 100 at that budget.
cheers
If you listen to music 50% you should be going for Marantz..........they work better for music!!!
oh btw, for speakers at that range, u will need something better than the 1713. 1713 wont do justice to those speakers. 1912 or yamaha 673 immediately comes to mind here..
Man ... I think I have to do some re-thinking ...
What do you guys think of the below combo's:-
YAMAHA RX-V473 & NS 8390 , NS-P60 , SW 215 or
YAMAHA RX-V473 & NS-F150 , NS-P150 , SW 215
Around 75-80K ...
At last I got my HT setup with the following:-
AVR - Denon 1612
Front - Polk tsi200
centre - cs10
rear - tsi100
subwoofer - psw110
The Profx guys did the setup manually without auddesy(I have doubt whether they have made current settings).
For some movies I have found that the voice from centre channel is not so clear though I have increased the volume of the centre channel to +5 db.
So I am thinking of upgrading the centre to cs20 and the front to tsi300.
I want to know to whether these will match with the power of Denon 1612.
Also will the cs20 give a significant difference than cs10 ?
i personally didnt like the polk centers, and have been in a center channel dilemma since a very long time. The rti series matching center is still decent.
The only center which kinda impressed me was the wharfedale, but i didnt like their fronts, sigh...
The cs20 is generally linked with the towers. Did you hear the RTi A4? same price, better performer
price wise cs20 & CSi A4 are same -which one is better?
will CSi A4 match with tsi300 fronts(i am shifting from tsi200 to 300 because easy placement of floorstanding spkrs.)
Also in stereo mode for music i have seen that sound from 200 has bass but voice is not crisp(perhaps it is missing midrange)
Need help urgently.
I found things missing in the rti A3 too. Somehow i didnt find the polk sound detailed nor crisp. Im not sure if the synergy is good, but with an 1612 amp, i would strongly NOT recommend floor standers to you. Not enough juice.
The price of (tsi300 + cs20) & (RTi A3 +CSi A4) is almost same.(I will not push my budget father)
I would like to know which one will be a better choice ? (dialogue clarity is most important).
Please help...:)
Hey , Where to get the best package deal for 1713 with DX 1 (wharf) or 1713 with CT 100 ( Paradigm ) ? Also suggest about the best prices !!!
