Best warm sounding center channel speaker
Anik06
Pune
Please suggest warm sounding center channel speaker. I have monitor audio bronze br2 as front speakers and denon 1713 AVR. My budget is around 15k.
Thanks a lot.
Anik
Anik- It is very important to timbre match the three front speakers in a HT environment and the center channel speaker plays the key role in this category. So the safest option would be to use three speakers of the same manufacturer, same model if possible. You can go with mix and match approach but that would require a lot auditioning in your room with the new speaker.
As Indranil sen suggested, timbre matched from the same series would be ideal fit.. But considering your budget, you may not be able to stretch for MA Bronze center channel..
If you don't have space issues of having an other MA BR2 as center, then you may check with the dealer if getting a single speaker is possible.. If so, it may be in within your budget..
