Try Monitor Audio bronze2 speakers.
Yes that's what I'm going to say but you already didPugal ji, it may cost over my budget 5 times......
sure friendHi, under strict tight 10k budget T15 are value for money I think, another option can be pioneer Andrew Jones Bookshelf, Boston acoustics a23, a26 they will go a little above 10k say 11 or 12 at least. And many options are from Taga.
However I basically use Polk , not the particular model but I can say Polks are nice speakers. Update here once you get a pair for yourself with pics
thank you Dr., please update ...I'll test my t15 tomorrow. Will update you with their performance.
