Budget 5.1 speaker set for HT.
TX SR506 (7.1 AVR) + SKF 4700 (5 ch package) + SL 107 (sub) = 42K
KBS,
By SKF 4700 (5 ch package) do u mean SKF 4700 + SKS 4700 + SKR 4700???
As SKF is only FS.
AVR is good but cant say same about speakers. I took audition of the same speakers at Sigma Mall. Not at all convincing. The same guy deals Jamo at competitive price. Talk to him.
TX SR506 + Jamo S 406 < 40k
So you liked Jamo 406 (5 ch Package) over Onkyo SKF 4700 (5 ch package) + SL 107 Sub???
KBS,
As SKF is only FS.
Saurabh,
This was is not my line. It was using this as "Quote" to reply to Vignesh Prabhu's post . Sorry for incorrect formating.
>>>>>So you liked Jamo 406 (5 ch Package) over Onkyo SKF 4700 (5 ch package) + SL 107 Sub.
Yes, I liked Jamo 406 & 606. 606 was obviously much better than 406.
It's my personal brother.
Saurabh,
Thanks, i also liked Jamo at this price range and am inclined towards it, so trying to get consensus :D
I had checked out the following
@Onkyo Showroom Sigma mall
1. TX SR506 (7.1 AVR) + SKF 4700 (5 ch package) + SL 107 (sub) = 42K
Was good for movies. Audio dint sound natural (or i can say not live).
As SKF is only FS???
Make sure that, you negotiate well. For ex Jamo S606 HSC3 + SUB200 (5.1 Package) is being sold around 55k, if you negotiate you can get for 45k.
Try to audition as many systems as possible within your budget and go for the one which you liked the most. Consensus may not help, focus on what sounds better for you.
please suggest me i am confused......i have almost decided to go for denon1610+ fusion 5 series package 42K., is it a better deal? compared to onkyo 506+ 4700 5.1 package 42k?
:sad:
Ok, system = AVR + speakers in this case... and the answer to your ? is yes.
Sorry my bad :o...
I'll re frame my question:confused:...
Have you bought the AVR and speakers? if yes from which one, whats the cost and from where???
Onkyo 504, Onkyo 6.1 speakers (may be HT-240, not sure), mail order in USA (don't remember the sites as it was 2yr+ ago), around 700USD. I am not sure why you are asking for these details, hope I have answered them to your satisfaction. :D
Oh... I thought u are also looking to buy as your profie does not have the gadget details;)...
Anyways thanks a lot for all the help :)
Well, I am indeed looking to buy... my speakers will be upgraded first... once you start this journey and get constant feeds from forums like HFV, the upgrade bug will overtake you completely :lol: there is no respite/cure...:D
:sad:
Certainly don't go for fusion 5.1 from profx, they are of no use on long run and build quality is not good though they look attarctive. May be the package is just made by BPL-India and marketed by profx. Think of any other brand based on ur choice.
I also listened to ProFx and even as a novice i did not liked it. I'll prefer Jamo 406 over it.
Finally I have bought Denon 1610 AVR :yahoo:
Thanks to all of you :o
Now i need matching speakers for it. My final goal is 5.1 setup.
Within in my existing budget of 25K for speakers either i can go for:
1) Jamo 406 5 speaker set and Sub 200 for 26K.
2) Yamaha NS 8390 (FS) - Rs. 8000/- + NSP60 (L/R/C) - 4750/- and some budget sub (for around 12 K).
Which one of these two is better??
Please suggest any other such setup, if any?
OR
I can take pair of decent floor stander for around 15K and a Budget sub for around 12K and later add the surrounds to it.
Which among the two will be better option??
Please suggest some decent FS for 15K....
Please suggest some budget sub for 12K, how is Jamo 200 Sub???
Please suggest keeping Denon 1610 in view...
Thanks....
Congratulations Saurabh!
For speakers, check out the 9.1 with SW150 or 9.5 from the diamond range. Contrary to the belief, 9.1 with SW150 will sound more authoritative than the current favorite 9.2
Happy auditions!
OR
Thanks....
mission m34i if u want FS, Wharfe 9.2/10.1/10.2 if u want BS.
Sub would be Wharfe PC10/Mission Sub/Polk110.
