Please google for 'building a PC,' 'DIY PC.' etc. Read two or three of the articles that you find there. In fact, study them.Also want to check :
- will I need to load a bios (I have no idea how to do it) ?
- do I need to set jumpers/switches on the motherboard ?
- do I need to buy fans/heatsink and glue onto the CPU
- do I need to buy fans for the case ?
- do I need any tools other than a screwdriver ?
What else do I need ?
Any help / suggestions most welcome..
For video playback rig like an HTPC: HDDs are better than SSD.
^^ A home PC is something else and has lots of applications and other stuff that loads. HTPC ideally has just the OS and Media Center Application, heck infact one can just opt to load media center avoiding the OS altogether. In that case the boot up time is more or less same.
You can test if you want, do a fresh install of windows and just load XBMC. Note the boot time, there would hardly be any major difference between your HTPC and home PC with SSD.
Its when you start to load other applications/softwares on the OS that SSD shines, as it can load multiple applications in super fast time..
And BTW this is not some theoretical suggestion. I also do own an 80GB SSD (Intel X-25M) in my Home PC.........![]()
For Perfect HTPC :yahoo:
Tks - thats very useful info.
Tks to all that responded so helpfully to my query.
Looks like this is doable even for me.
Its not perfect for HTPC,,,,,,,its super over kill for it..... This is pure gaming card, with multiple displays and heavy duty animation rendering stuff.
Wrong this card is made specially for HTPC use.Do you know what is HQV Vida if not please google it.
http://www.avsforum.com/avs-vb/showthread.php?p=20584858
The Silicon Optix Emmy award winning HQV video processing technology enables the sharpest and most detailed HD images possible by utilizing features such as true 1080i-to-1080p HD deinterlacing, and a sophisticated multi-directional diagonal filter that ensures video free from jagged edges. HQV technology also enables SD material to approach HD quality by employing advanced scaling, per-pixel detail enhancement, and noise reduction technology that removes noise and artifacts caused by compression.
Friends,
I am planning to change the cabinet for my HTPC as its currently a big cabinet due to which its lying on the floor in my hall.. and making it look messy.
Thought of changing the cabinet to a smaller i.e close to 13 inches in height and depth however seems like i cant do that unless i change my mobo as well.. as i have "Intel C2D + intel 965 mobo + HD 5570 based HTPC"
I have liked one of the Cabinet considered by OP for his built .. which is " CFI Cube "
I have two questions and wish to get answers for same with your help :
1) Can I remove the PSU that comes with the proposed cabinet and use my existing PSU which is around 400 - 500 watts? will my PSU fit in CFI Cube case?
2) Assuming which ever mobo i buy can accommodate my Graphics card.. will it be able to use it in CFI Cube or its height may pose some issue?
Naren
Then i came across your Almost Perfect HTPC thread..and looked at the cases you had considered.. seem like CFI cube will be perfect for me and is also not too expensive.. however i may have to change the mobo to mini ATX...
Now i have one question for you.. i have Radeon 4850 vedio card.. and for that reason i had changed my psu to a 500 watt psu ( or may be 400 wats ) so i may want to use that psu even in the CFI Cube ( if i am buying it)
Is it possible to remove the psu that comes with the CFI Cube and replace it my PSU that i am using currently ( the one with 400 or 500 watts)
I am not sure if PSUs come in different sizes, hence this question.
Also do you have any other VFM solution for me in mind? if so please do share that as well..
Thanks for your help in advance and hope to hear from you soon.
Naren
2. Most cabinets that are smaller in height (Recently got a Silverstone ML-03) will only accommodate graphics card of half height. Regular PCI/x cards will not work.
The silverstone ml03 is out of stock. Three months back I ordered one in primeabgb and they didn't ship it for a week. They kept delaying the shipping saying that it will be shipped today, tomorrow and atlast that they can't ship to my location. I requested a refund. After making the refund, they quickly removed the listing from their website and ebay store.
ML03 is a very good htpc cabinet, but there are restrictions like the SMPS length should not be more than 140mm, supports only low profile card etc.
